It is currently Thu Jul 31, 2025 5:42 am
 Post subject: van rear lower sections
PostPosted: Wed Apr 05, 2006 1:08 pm
i didnt want to hijack another topic so:
has anyone used replacment rear lower corners on their van/eastate? im talkin about under the petrol filler arround to below the door hinge, the 3 inches from the seem up that rusts away, ya know? :roll:
has anyone used the panels you can buy from the uk? how good are they because there damm cheep.
PostPosted: Wed Apr 05, 2006 1:29 pm
High heel ninja
My van had rust there too, but we just plated it, so no i did'nt use the panels, seemed easier to plate as it was a flat surface.
Doogie
PostPosted: Wed Apr 05, 2006 2:01 pm
yea, mines had that done on one side...badly, and now its gone on both sides and arround the corner, im not keen to do it in two parts and leave the corner.
PostPosted: Wed Apr 05, 2006 2:19 pm
I'm guessing you saw my pics in the other threads, but anyway,
I just used some 1 point something mm thick zinc plated steel.
See pics here: http://zizzle.blogspot.com/2005_03_01_zizzle_archive.html
PostPosted: Wed Apr 05, 2006 2:27 pm
yea, i saw one of your pics, just had another look, yours has gon almost exactly the same as mine, so did you just bend up the outer skin and butt weld it? youve done a nice job!
PostPosted: Wed Apr 05, 2006 4:05 pm
I didn't pre bend. The angles are a little off down there, as the rear of the van slops forward as you know.
I welded the longer straight section that is just behind the wheel arch as normal. Then as I got the corner I would weld a little, then tap it around gently to match the curve, weld that part that lines up, repeat...
The strip I cut was deliberately wider down in that section. Sometimes while bending, the steel wouldn't fit in the gap. Just grid it to make it fit as you bend and weld.
Don't be scared to experiment. The worst that happens is you have to grind it off and do it again. Although, if you use your brain, you should rarely have to.
Do you plan on doing the inner skin too?
PostPosted: Wed Apr 05, 2006 4:32 pm
yea, ill have to do the inner skin too, but im not worried about that so much because it cant be seen from inside or out, and mine isint quite so bad. its the outter thats going to be dificult as mine isint lined, so its going to be visable from both sides. its a few months off yet before its going to even get started, but its good to research a bit first.
