Fitting Front subframe. https://www.ausmini.com/forums/viewtopic.php?f=2&t=17906 |
Author: | clubmn [ Wed Apr 05, 2006 9:06 pm ] |
Post subject: | Fitting Front subframe. |
When fitting the front subframe, Is there rubbers (bushings) that go in between the body and the subframe, On the top mounts? |
Author: | JC [ Wed Apr 05, 2006 9:42 pm ] |
Post subject: | Re: Fitting Front subframe. |
clubmn wrote: When fitting the front subframe, Is there rubbers (bushings) that go in between the body and the subframe, On the top mounts?
Assuming you have an ozzie car, no, no rubber. Dry type suframes have a metal spacer, not certain if the wets have it though. |
Author: | simon k [ Wed Apr 05, 2006 9:56 pm ] |
hydro ones don't have the spacers... |
Author: | clubmn [ Wed Apr 05, 2006 10:06 pm ] |
Post subject: | mini |
The spacer sits between the subframe and the body? RIGHT..... The what washers are used for the top?, Just a split washer and 1/2"nut. |
