It is currently Sun Jul 27, 2025 3:56 am
 Post subject: Rod Change Rekit/recon
PostPosted: Tue Apr 11, 2006 3:09 pm
ChrisZ told me about a rekit or recon for a rod change
which involves changing cup/ball/pins?
heritage mg doesnt have anything
minispares padstow says theres a trade in for a recon thing for $150
can youse enlighten me on this matter?
tenks
Inconspicuously Conspicuous
PostPosted: Tue Apr 11, 2006 5:51 pm
I have replaced the cup/socket that the gear stick sits into and also replaced the 2 bushes inside the housing. I bought the bits from Mini Kingdom way back in 97, I remember back then even it was a mission to track down part numbers......
PostPosted: Tue Apr 11, 2006 6:26 pm
Duc just get one from mini clinic. they need the business.
Maybe karcraft have them as later rovers were rod change?
You need to get
1- new gear stick
2- new thing that the gear stick goes in (i call it a cup)
3- new bushes (for memory im sure there are little things that you need to tap in)
speak to mini clinic as you can buy all the parts seperate, but maybe a exchange one would be just as easy,
PostPosted: Tue Apr 11, 2006 7:12 pm
thanks chris and hanra
larry wasnt very sure what i was talking about.
i will enquire again soon
:wink:
PostPosted: Tue Apr 11, 2006 10:28 pm
The cup/socket is a fairly brittle metal, i remeber when i broke 1 when i tried replacing mine, when i was tapping the pins through for the rod, it just smashed to pieces..... I wasnt even using much force?
Users browsing this forum: JM1275 and 81 guests
