Engine missing, need help!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=18010
Author:  snowie [ Sun Apr 09, 2006 6:43 pm ]
Post subject:  Engine missing, need help!
Lately my mini's been missing badly. We have tried fixing the most likely causes, Spark plugs, leads, checked dizzy for cracks and cleaned it. I took it down to brickworx and steve told me to put a standard type coil in it (I had a compact bosch one from my old engine) and Champion plugs. Did that and it still misses. The wierd thing is that it idles beautifully and runs perfectly when it's cold but as soon as it warms up and you give it a few revs it turns to crap. I also found that when it gets really bad and I have to pull over I turn the engine off for about 20 seconds and then it runs fine for another few minutes? It's a Single point injected engine so could it be a fault in the computer?
Author:  czerial [ Sun Apr 09, 2006 6:51 pm ]
replace the condensor in the distributor mate. :wink:
i have had the very same issue with my car a few years back. will'
make the world of difference
Author:  min13k [ Sun Apr 09, 2006 6:57 pm ]
snowie has it got one of them white ceramic things on the coil ??? resister
if so it could be getting hot and earthing out ....
makka
Author:  snowie [ Sun Apr 09, 2006 7:04 pm ]
I don't think so, I can't see it. It did come with a small silver cylinder thing that plugged into the coil but my dad said I didn't need it and it's worked fine without it for ages.
Author:  min13k [ Sun Apr 09, 2006 7:08 pm ]
that would be the condensor
is it electronic or points dist ?
makka
Author:  JAM_IT [ Sun Apr 09, 2006 7:25 pm ]
what Chris said.
Author:  snowie [ Sun Apr 09, 2006 7:29 pm ]
it's electronic ignition
Author:  drmini in aust [ Sun Apr 09, 2006 7:34 pm ]
I've heard the ignition modules on those dizzies have been known to go bad when hot. :cry:
