Paint Stripping- acid dip
https://www.ausmini.com/forums/viewtopic.php?f=2&t=18029
Author:  Mr_gts [ Mon Apr 10, 2006 11:22 am ]
Post subject:  Paint Stripping- acid dip
Hi there guys,
Just wondering if anyone would know where I can get some body panels acid dipped to strip the paint off them
(within Sydney)
Author:  clubmn [ Mon Apr 10, 2006 11:30 am ]
Post subject:  mini
Have you looked into beed or sand blasting. I got my mini blasted with sand. And it came up a treet, I have heard people say that it can distort panels, But i found that to be bull.
Author:  Mr_gts [ Mon Apr 10, 2006 11:34 am ]
Yeah I have had a few things blasted and they have been damaged in the process,
There are just a couple of things i would like to get dipped if possible
Author:  aznpride [ Mon Apr 10, 2006 11:42 am ]
When my old man was restoring his Pontiac, he had the front guards and the bonnet acid dip, and sandblasted the remainder of the vehicle. Came up really good.
Author:  cush [ Mon Apr 10, 2006 12:10 pm ]
apparently, acid dipping strips paint in areas that you can't get paint into...
leaving bare metal to rust away out of view...
Author:  jbeenz [ Mon Apr 10, 2006 12:23 pm ]
im board, so heres my thoughts
I have read that you can sand blast using a wider fan, the process has a different name, but basicly it is faster and prevents distortion.
Alternitivly there is a process called plastic media blasting which takes off as bad paint and bog, leaving a primable surface.
Author:  EST-071 [ Mon Apr 10, 2006 1:50 pm ]
Or you can use Soda Plasting.
www.sodablast.com.au/
They will also come to you.
Pete
