Well the Mini has been going pretty well, until lately its been running pretty not so good. I stopped the other day and removed the dizzy cap, and touched the rotor button, put it back together and it ran much better (noticably). So I thought I should replace the points, which is what I did yesterday. Now it wont start at all
So I thought I would put the old points back in for starters to make sure it wasnt the new points the problem, but Im not positive how the wires should connect to the breaker set.
There are two wires, one goes to the capacitator (earth?) and the other comes into the distributor from somewhere else.
The silver tab wire (has a silver metal bit that attaches to the points) - does that go on the bottom and makes contact with the points?
then the rubber seperator
then the wire with the brass tab?
and then the nut to hold it all to the points.
Problem is the silver tab has a little "tab" that is bent up/down, it appears that the tab should face outwards and then would contact with the brass coloured tab but this doesnt make sense as Id expect they shouldnt touch. When I pulled the old points out I didnt notice which way the wires were facing (*slap on wrist).
They are GL19 points.
Can you tell me:
The tab on the silver tabbed wire - does that tab face toward the points or outward toward the brass coloured tabbed wire?
Shheesh, thanks if you can help
Jill
