Battery Sticker?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=18194
Author:  =twista= [ Sat Apr 15, 2006 9:59 pm ]
Post subject:  Battery Sticker?
Is it an upside-down Blue triangle - Solid
or is it an upside-down blue triangle with the arrow going down the middle pointing down?
Author:  Morris 1100 [ Sat Apr 15, 2006 10:05 pm ]
It is a blue triangle. It does not matter which way up you have it.
If the battery is fitted with a cut out switch the blue triangle has a red spark across it.
Author:  sports850 [ Sat Apr 15, 2006 10:05 pm ]
I've seen an upside down and right way up solid blue triangle , plus one with a lightning type jagged line in the middle of it . I thought the reg's normally just said a blue triangle to indicate the position of the battery ....
Author:  Morris 1100 [ Sat Apr 15, 2006 10:14 pm ]
The blue triangle is to show the location of the battery.
The blue triangle with the red spark is to show the location of the cut out switch.
Author:  =twista= [ Sat Apr 15, 2006 10:53 pm ]
thanks fellas,
