Cooling system flush whats the best commercial cleaner https://www.ausmini.com/forums/viewtopic.php?f=2&t=18228 |
Author: | Gadgets mini [ Sun Apr 16, 2006 11:28 pm ] |
Post subject: | Cooling system flush whats the best commercial cleaner |
going to flush out teh cooling system and Radiator soon thinking about using a chemical cleaner to help get rid of teh crud can anyone give me any tips on whats teh best product to use, tips, and products to stay away from. Cheers |
Author: | Stuwey [ Sun Apr 16, 2006 11:37 pm ] |
I used the LocTite one and it did seem to make a worthwhile difference... The 'other' ones don't seem to do much at all. |
Author: | willy [ Mon Apr 17, 2006 1:18 am ] |
ADELAIDE TAP WATER. Cooling SA minis for years and years, and quite well at that. PAH, coolant is over rated ![]() |
Author: | Mike_Byron [ Mon Apr 17, 2006 10:14 am ] |
The lucas products are pretty good but nothing is going remove a build up of mud and slush from a radiator except either a new radiator or having the tanks removed and wires pushed down the cores. A mini doesn't have much cooling capacity to spare and even a 10% reduction in efficiency will make them begin to overheat. So locating all the reasons it overheats is important. With all the sludge removers, follow the instructions and dont leave it in longer than recommended and they will eat through worn thin radiator cores. |
