No Spark https://www.ausmini.com/forums/viewtopic.php?f=2&t=18256 |
Author: | Gezo [ Mon Apr 17, 2006 7:26 pm ] |
Post subject: | No Spark |
Hi, The car is a standard 1100 clubman 71. When trying to start, I have spark at the points but no spark at the plugs. Obviously the car won't fire. Any tips. Thanks |
Author: | sports850 [ Mon Apr 17, 2006 7:30 pm ] |
Check the condition of the rotor button , distributer cap and the plug leads . Check also that someone hasn't put a little bit of plastic on the end of the coil lead or similar . Also check the little carbon tip is still in the centre of the distributer cap . |
Author: | The Toolman [ Mon Apr 17, 2006 7:42 pm ] |
Had the same problem this week, has spark at the points but not at the plugs.... It turned out my new coil crap itself, do you have a spare coil you could try? |
Author: | sherman67 [ Mon Apr 17, 2006 8:11 pm ] |
yer follow what sport 850 said it shouldnt be your coil if u have spark at the points |
Author: | Gezo [ Thu Apr 20, 2006 5:59 pm ] |
Hi, My spare coil fixed the spark problem to the plugs. Still won't start. Will have check timing. thanks |
