It is currently Mon Aug 18, 2025 12:22 pm
 Post subject: Identify this please..
PostPosted: Tue Apr 18, 2006 10:37 am
12YDTAH10766
This number would identify the block, but did they come factory with the big valve heads???
Thanks.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Tue Apr 18, 2006 10:49 am
They came with a 12G940 head which has an unshouded combustion chamber and relatively large valves and ports as compared to earlier small bore heads such as the 12G202 heads.
PostPosted: Tue Apr 18, 2006 12:57 pm
So basically, that motor worked to 1310cc with that head should go pretty good???
Santo
"The Lone Ranger"
PostPosted: Tue Apr 18, 2006 1:06 pm
Short answer - yes
Its what I have on my 1310 mini and it goes fine. My motor has a MG metro cam, HIF44 carby, extractors and it will go faster than i want to drive it.
Of course the head can be improved considerably by a good gas flow professional but they were pretty good heads straight out of the factory. They breath well compared to the relatively inefficient heads on earlier small bore motors
PostPosted: Tue Apr 18, 2006 8:00 pm
The 1100S head is basically the same casting as a Mk2 Cooper S head, except the inlet valves are 1/16" smaller and it has single valve springs not double.
Very easy to fit S inlets, these days it's a common way to make up for worn valve seats.
If exhaust seats are worn, fitting unleaded inserts is a good remedy. :wink:
Users browsing this forum: Bing [Bot] and 358 guests
