It is currently Tue Aug 19, 2025 8:03 pm
PostPosted: Tue Apr 18, 2006 11:11 pm
does anybody know the tappet clearance for the later model 1275 injected models, is it the same as the older engines or different?
Mini Clubman, 1.3i, air con, 12" mags, pioneer sound system.
PostPosted: Tue Apr 18, 2006 11:25 pm
The valve clearance for engines with a 12A prefix should be 0.33 to 0.38mm
All other engines should be set to 0.30mm
Just need to check whether your engine number starts with 12A******** or not.
PostPosted: Tue Apr 18, 2006 11:30 pm
thanks heaps for that will check the number
