It is currently Thu Jul 17, 2025 7:46 pm
PostPosted: Thu Apr 20, 2006 6:00 pm
1974 Leyland Mini
1 1/2" SU Carbie
Currently has a BQ needle and is running Rich.
Black smoke, doesn't idle, sometimes doesn't even run all the cylinders.
When you floor it is almost konks out.
Aparnetly it ran fine on a 1100cc
I have got extracters and an aftermarket inlet manifold.
And on a side note, the sexiest dual exhaust ever heard.
What needle do I need?
Please help.
PostPosted: Thu Apr 20, 2006 7:24 pm
whinja ninja
whinja ninja
Theres a program you can download, called WINSU. It has a feature where you put in your engines details, and it tells you what needle. You can only use this ferature a couple of times unless you pay for it.
I don't know my name anymore.
PostPosted: Thu Apr 20, 2006 7:27 pm
have it looked at by a mini specialist please...it may well be more than just a simple needle change
there`s all sorts of "other" reasons for running rich too
 Post subject: Yep...
PostPosted: Thu Apr 20, 2006 7:29 pm
Yeah....there is a needle exchange program :roll: ...get the bugger tuned professionally :idea:
PostPosted: Thu Apr 20, 2006 8:00 pm
I am running a stock 998 with HIF38 (1 1/2"), RAMFLO filter and an ADS needle. Car never misses a beat and runs excellent!
Standard for an HS4 is ADF I believe.
Website: www.justanothermini.com
PostPosted: Thu Apr 20, 2006 10:56 pm
Lets assume I have tried alot of other things to get it to work before resorting to the needle.
I tried running WINSU, but it gives me a .net framework error.
So I installed the framework it links me to.
Restarted,
Still doens't work.
I have taken my Carbie into my local mini shop and each time I got in, a different person gives me a different answer.
Which has been costly so far.
Please, cant someone save the day with their massive........... intelect?
PostPosted: Thu Apr 20, 2006 11:12 pm
OK for starters, if it has a BQ needle now it is a fixed needle carb... the floating needle that JAM_IT listed won't fit.
Only book I have handy that lists any needles for HS4 carb is the Leyland black workshop manual.
It has a listing for a 998 automatic with HS4 (1-1/2") carb-
Std needle AC
Rich needle M1
Lean needle H6,
Blue spring in dashpot.
Hope this helps.. :wink:
Buying needles is a lottery, there are hundreds of `em.
Try this program- http://www.teglerizer.com/suneedledb/index.html
and, this- http://www.mintylamb.co.uk/suneedle/
I'd find someone with a dyno and an A/F meter, that tunes SUs- do it properly... :wink:
They should only charge you for the needle they use, not for a bunch of them.
As TheMiniMan said it could well be another problem, flooding, air leak, etc.
