Valve Saver?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=18439
Author:  64mini [ Sun Apr 23, 2006 4:39 pm ]
Post subject:  Valve Saver?
I run 1ml Valve Saver per Litre of fuel (95ron all I can get here).eg. 20litres = 20ml
Now I have a modded motor, cam, head etc....I been told I should double the dose.
What do others use?
Should I be adding more to protect my Valves?
Mike
Author:  CPOCSM [ Sun Apr 23, 2006 4:47 pm ]
Keep it at 1 ml per litre. More will just gum everything up. I use flashlube at 1ml per litre.
Hooroo
Rob Forsyth
Miniot!!
Author:  drmini in aust [ Sun Apr 23, 2006 4:50 pm ]
I run the 1mL/Litre of Flashlube valve saver in my 1360,
When I stripped it last (valves & seats had done 30,000 miles) they were fine- all clean and no valve seat recession. I reckon the standard amount is OK.
If you run NONE after rebuild, I'd give the seats 6 months before needing recutting- I proved this (just for fun) with my son's 1100 Clubby.
Author:  andbat [ Sun Apr 23, 2006 5:58 pm ]
i thought when you had a rebuild you have a un-leaded head put on and no longer use valve saver.? like every other car. or atleast if you ahve an unleaded head put on.?
Author:  drmini in aust [ Sun Apr 23, 2006 7:25 pm ]
My 1360 is pretty well ported out, it had oversize (31mm) exhaust valves fitted when done up years ago- no ROOM there for unleaded inserts... 8)
Fitting inserts is an option, I shrink fitted Rover ones to our 1293 when I did it- but that head is near stock. It runs 95 octane and NO additive.
Wife's car... :wink:
Author:  64mini [ Sun Apr 23, 2006 8:46 pm ]
Well when fitting the oversize valves to the head I was told the converting to unleaded was very difficult to do.
Author:  68matic [ Sun Apr 23, 2006 9:00 pm ]
use the stuff, cant hurt can it
also stops pinging
