It is currently Tue Aug 05, 2025 8:33 pm
 Post subject: Door Hinge Resto?
PostPosted: Mon Apr 24, 2006 6:55 pm
I'm having the car resprayed etc, and won't to fix the sagging door hinge's. There is a bit of play in them. What are my options?
I know i can do exchange, but how much would i be looking at?
Can i fix them myself, or would i be able to get them done locally/
Cheers Ryan!
PostPosted: Mon Apr 24, 2006 6:57 pm
You can fix them yourself.
All you need is new bushes and pins.
One bush, and one pin for each hinge.
Around $30 do to all 4 hinges i think ?
No more Minis!......For now.
PostPosted: Mon Apr 24, 2006 6:59 pm
How do i do it?
Do i need any special tools?
Is it hard?
Cheers ryan
PostPosted: Mon Apr 24, 2006 7:03 pm
Kazjim and I did mine about 2-3 weeks ago.
We used -
Hammer
Drill
Grinder (with wire wheel attachment)
Used the grinder with the wire wheel to remove all paint from hinge as to get to the pin and for respraying.
Punched out the pin using a hammer. We placed the hinge on a bit of wood with a hole under the pin, that way we could hammer the pin with a hole punch (or similar) without stuffing the hinge. [A vice would have been used if there had hav been one...]
Used a drill to drill out the old bushes. Make sure the drill bit is slightly smaller than the hole or you will bugger the hinges. My bushes were well gone.
Once you have gotten the pins and bushes out, hammer in the new bushes (be careful and dont stuff them by hammering to hard)...tap them in.
Put the hinge together, and hammer in the pin.
PostPosted: Mon Apr 24, 2006 7:44 pm
What he said ^^^
The pins are 1/4" diameter.
I would add that if the hole in the middle part is well worn, a new replacement bush (5/16" O/D x 1/4" I/D) will not fix it.
When I did mine I had to make thicker bronze bushes, I made the O/D 9.0mm.
Don't go much bigger, or the hinge will be too weak....
PostPosted: Mon Apr 24, 2006 7:56 pm
or my way, i bought 2 6mm drill bits, pushed the old pin out with pin punch, then drilled thru with new drill bit and then taped it to the straight shaft part of the drill and cut it off flush in the hinge, u can do one side per drill. the steel in the drill bit is hardened so it takes along time to wear again
PostPosted: Mon Apr 24, 2006 7:58 pm
drill bits $3.20 each and 1.68 for a 125x1 mm cutting disc
PostPosted: Tue Apr 25, 2006 12:18 am
Interesting idea there dodge.
So the drilling didn't make the hole too big for the base of the same bit? I get you need to stop drilling as soon as it punches through?
Users browsing this forum: Majestic-12 [Bot] and 77 guests
