door edge protectors https://www.ausmini.com/forums/viewtopic.php?f=2&t=18502 |
Page 1 of 3 |
Author: | minichick [ Tue Apr 25, 2006 5:33 pm ] |
Post subject: | door edge protectors |
Hi all... am looking around for a clear door protector for my GT. Not sure if they exist, that's all. My idea is a see-through strip that is made of soft plastic and it would slip on the outer edge but be almost invisible, if you know what I mean. Most things I've seen are ugly and dark coloured (mine is white) and will spoil the line. Because the doors swing out wide in that lovely 1970's basic way, it's frustrating always having to grab it before it hits something. Any ideas? minichick |
Author: | JAM_IT [ Tue Apr 25, 2006 7:07 pm ] |
Can't help you directly with your question, but indirectly.......in my garage I have glued some firm sponge rubber onto the walls next to where the doors open. That way I can push the door open till it hits the foam rubber, and not worry in the slightest about damage. ![]() That may or may not help you. |
Author: | Marvin [ Tue Apr 25, 2006 7:45 pm ] |
Screw one of these door stops to the door ![]() Sorry couldn't help it. ![]() |
Author: | sports850 [ Tue Apr 25, 2006 7:54 pm ] |
Just a thought , how about running some of the chrome strip from the bottom seam vertically on the door edge , it might protect it from some hit's but unfortunately not a big hit , at least chrome will look a bit better than the big sticky out black with reflectors type protector the auto places sell . And of course anything is better than Marvin's suggestion ..... |
Author: | Marvin [ Tue Apr 25, 2006 7:56 pm ] |
sports850 wrote: And of course anything is better than Marvin's suggestion .....
Author: | minichick [ Tue Apr 25, 2006 8:57 pm ] |
Post subject: | Door stops...hee hee |
Yes, Marvin, the door stop idea is the way to GO! I think i'll just have to wait till I see what I have a vision of. I can't believe that my idea isn't out there somewhere in some auto shop. As you say, the ones on the market are just horrible. Black, silver with ugly refelctors...mmmm As a stop gap, I wonder if white electrical tape would take any paint off? Could be a good temporary measure. cheers, minichick |
Author: | Marvin [ Tue Apr 25, 2006 9:09 pm ] |
Post subject: | Re: Door stops...hee hee |
minichick wrote: Yes, Marvin, the door stop idea is the way to GO! Cool... I FINALLY made a contribution to the forum ![]() minichick wrote: I wonder if white electrical tape would take any paint off?
I doubt it would |
Author: | Mini Mad [ Tue Apr 25, 2006 9:17 pm ] |
Electrical Tape wouldn't remove paint... You want something like this: http://www.ozicozi.com.au/ |
Author: | steamer [ Tue Apr 25, 2006 9:51 pm ] |
If you want to stop the doors from swinging way open attach straps made from seat belt type material between the front edges of the door and the body get what I mean? |
Author: | Mini Mad [ Tue Apr 25, 2006 10:00 pm ] |
All mini's have the seat belt strap there..(or metal clip) if not then the hinges would break everytime you over opened it. |
Author: | Harley [ Tue Apr 25, 2006 10:05 pm ] |
Mini Mad wrote:
Failing that, use either clear contact or some body coloured vynil. ![]() |
Author: | steamer [ Tue Apr 25, 2006 10:08 pm ] |
not if they have been resprayed as I have come across quite a few that dont have it. (mostly round nose) |
Author: | minichick [ Tue Apr 25, 2006 10:12 pm ] |
Post subject: | straps |
mine has the strap...but it still can easily hit something when it opens up, especially on a slope. I could try and shorten the strap a bit. The other ideas are good for temp measures. |
Author: | minichick [ Tue Apr 25, 2006 10:16 pm ] |
just been that ozicozi site. looks pretty good stuff. However, they seem to want to quote and do the whole car etc. The factory is 5 mins from where I live. I might drop in, see whatb they say about the door edges... ta for the pointer. |
Author: | Mini Mad [ Tue Apr 25, 2006 10:57 pm ] |
Try looking into the metal clips that replace the seat belt strap, they are more like modern doors in the way they open and have a couple of positions you can lock the door at. |
Page 1 of 3 | All times are UTC + 10 hours |
