Whats it worth your reckon? https://www.ausmini.com/forums/viewtopic.php?f=2&t=1852 |
Author: | Toddles [ Fri Sep 10, 2004 12:41 pm ] |
Post subject: | Whats it worth your reckon? |
Ok guys I am just trying to get an idea of how much it would cost to turbo a gti engine. This is the go, lets say its geting whacked into a clubman. All I want to know is how much it would cost to get everything needed to make the engine a turbo engine, an idea of what sort of parts are needed and if things like a front mount would fit. Don't want to do any body mods, and want to keep the engine stock internals etc...so how much boost could be run on a stock engine? I think that all makes some sort of sense, anyway just lend me what ever information you have. Thanks Todd |
Author: | simon k [ Fri Sep 10, 2004 1:57 pm ] |
what sort of GTI ? peugeot, proton, there are plenty of them ??? if it's not an A series, I suggest you go to a specialist for the car the engine came out of |
Author: | Toddles [ Fri Sep 10, 2004 3:08 pm ] |
sorry its a suzuki gti engine. Its obvious that its not an A series but a lot or people on here do have knowledge about things other then just mini engines. |
Author: | 13secmini [ Fri Sep 10, 2004 4:05 pm ] |
to turbo a g13b you will need: Turbo: $200-$2500 Manifold: $400-$700 dump pipe: $200-$300 Oil delivery line: $40? Oil return: $70 Water lines in and out: $100 piping from turbo to inlet $50 that will get your engine to boosted, but how long will it last standard? You will also need an, extra injector+ controller: $250 adjustable fuel regulator:$199 fuel pump: $199 blow of valve: $100-300 brad. |
Author: | Toddles [ Fri Sep 10, 2004 4:42 pm ] |
Thanks brad, it at least gives me some idea of the cost involved. If/when it actually happens it would only ever run low boost so it should last a while and if and when it does pack it in, makes a good excuse to rebuild the engine. Thanks again brad. |
Author: | PhildoD [ Fri Sep 10, 2004 9:54 pm ] |
If ya want some more info ya could get in contact with Con Torisi, he has/had a turbo GTI clubby. His webstie is : http://www.twincamturbo.com/ |
Author: | MiniK [ Tue Sep 14, 2004 11:39 am ] |
http://www.redlinegti.com Go there.......itll tell you want you want to know about the suzi motor. |
Author: | 13secmini [ Thu Sep 16, 2004 12:48 pm ] |
This could be a good start todd?? http://forum.hot4s.com.au/messageview.c ... adid=25515 Its a manifold with a t2,t25,t28,gt25 flange, some heat shield, and turbo for $400. Send him an email for some pics. |
