It is currently Tue Aug 12, 2025 7:36 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
 Post subject: Shell Prep
PostPosted: Wed Feb 15, 2006 12:37 pm
Die Die Die!!
ok, i have willy's Morris Deluxe shell, what would u recomend i do to get it to a show class finish
i was thinking along the lines of this
1. grind/wirewheel
2. deaden inside, boot, firewall, underide
3. por-15
4. prime
5 .paint
6. gloss
7. cut and polish
PostPosted: Wed Feb 15, 2006 1:31 pm
Spray bog :? I'd try and get the majority of the dent/s out, then only use a small amount which is sanded back any-way. (Is that what u ment by spray bog)? If you have the space/time...could make up a Rotisserie, be able to get at every-part of the car.
PostPosted: Wed Feb 15, 2006 1:44 pm
Die Die Die!!
yeah spray bog is used to get rid of the fine imperfections that i may go over...and yes percentage of it will be sanded :)
PostPosted: Wed Feb 15, 2006 3:08 pm
Will you be doing the work or have you got a mini budget like Evil 850?
PostPosted: Wed Feb 15, 2006 3:24 pm
Die Die Die!!
ill be doing the work... or most of it, getting help wherever possible...
PostPosted: Wed Feb 15, 2006 3:27 pm
blast
fix dents/rust
bog etc etc
high fill primer
basecoat couple coats of clear
you will probably need to get that boot panel pulled out ona jig and definentally anew bonnet
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Feb 15, 2006 3:42 pm
Die Die Die!!
im getting a roundnose shell, so i wont have to worry bout that ... and knowing my luck ill have to worry bout something else...
PostPosted: Fri Mar 17, 2006 5:04 pm
Die Die Die!!
What Do people rekon is a good deadner (rust kill/sound deadner) ??
 Post subject: Re: Shell Prep
PostPosted: Fri Mar 17, 2006 5:20 pm
_666_ wrote:
ok, asuming i have a normal mini shell, what would u recomend i do to get it to a show class finish
1. glass bead sandblast
2. fix rust/dents
3. spray bog
4. deaden inside, boot, firewall, underide
5. prime
6 .paint
7. gloss
8. cut and polish
you have all the steps but not in the right order, 1 & 2 are ok 3 etch prime 4 Prime 5 rub back 6 fix imperfection with spray bog or hand putty 7 prime repaired areas and rub down 8 paint 9 underside and wheel arches with deadener or body shutze and you can paint over it then 10 cut and polish
Jon
PostPosted: Sat Mar 18, 2006 6:34 pm
I would etch prime straight after blasting the shell. That way you minimise the risk of surface rust.
You can easily grind off the etch if you have to do any weld repairs.
If you have to skim fill over any dents, it is better to have a coat of etch under the filler as filler absorbs moisture over time.
This is my opinion only and others might think differently.
Website: www.justanothermini.com
PostPosted: Sat Mar 18, 2006 11:15 pm
Die Die Die!!
cheers, as i have a half rubbed back shell (willy's old one) i need to do something bout it soon..
PostPosted: Sun Mar 19, 2006 2:30 pm
thats stuffs great its about $10-$20 a tin and u would use bout 3
all u have to do is clean the dirt and rust over it then spray over it :wink:
PostPosted: Sun Mar 19, 2006 3:00 pm
Die Die Die!!
awsome nice and easy... would it be suitable for the firewall in the engine bay ?
PostPosted: Sun Mar 19, 2006 6:53 pm
No offence, but I can't stand that stuff!! :evil: I reckon it traps moisture where it shouldn't, and looks yukky.
Seriously, what do you gain from it?
PostPosted: Sun Mar 19, 2006 7:00 pm
Online
If water gets into the car, Anton, you want to keep it away from the steel. You need something that won't crack over time, that has good adhesion. That's why I used 2-pack tar epoxy on the floor of your 850. It's watertight, as you know! 8)
Users browsing this forum: drmini in aust and 244 guests
