Remove front mounting from rear subframe https://www.ausmini.com/forums/viewtopic.php?f=2&t=18652 |
Author: | Blokeinamoke [ Sun Apr 30, 2006 5:18 pm ] |
Post subject: | Remove front mounting from rear subframe |
I am trying to remove the front mounting from a dry moke subframe. Do you undo the not near the readius arm and drive the bolt out or do you remove the curcular retainery thing on the end? (Circular thing with two holes is it) If the whatsy on the end how do you remove it. (Circular thing with two holes is it) |
Author: | 9YaTaH [ Sun Apr 30, 2006 5:46 pm ] |
Post subject: | Neither?? |
Don't think it is any of those thingys....there are two bolts that point towards the front of the car...and they are just to the left of the swing arm....do you have a technical manual??? |
Author: | awdmoke [ Sun Apr 30, 2006 5:52 pm ] |
You lost me with your technical terms Blokeinamoke ![]() but what he^ said. Use half a can of CRC, then only two of the bolts should snap off in the threaded plates (the ones that stick into the battery compartment). |
Author: | Blokeinamoke [ Sun Apr 30, 2006 6:29 pm ] |
Here we go again. 1. The rear subframe is out of the car 2. The radius arm arm have been removed 3. The two bolts behind where the radius arms were have been removed I am trying to remove the front subframe mount from the subframe. It haa a round ending witgh two holes facing away from the subframe. I cannot see a way of remving these and therefore the mountings. I do not have a technical manual as it was out of the library today ![]() |
Author: | Blokeinamoke [ Sun Apr 30, 2006 8:14 pm ] |
Found the answer. Thanks for helping ![]() |
