I put a chain through the rear subframe, in front of the rubber cone & link it together with a D shakle, the i attach a 2000KG ratchet strap the the castor bars & run it around a 1 inch square peice of tube on the front of my trailer, and ratchet it tight, it pulls the car forward & locks it solid.
3 trips to Melbourne, 1 to Brisbane, 8 to Hay & hundreds of trips round Sydney & the car has never moved a milimetre, i recently tried strapping over the wheels to allow the cars suspension to work to absorb the bump, big mistake as the trailer got light over bumps & wanted to sway at 110kph, i crap basically.
Saying all that it depends on how the trailer you are using is equiped with mounting points.
Here's a few pics of how i attach cars to trailer
Doogie
