Handling with 13X7 wheels https://www.ausmini.com/forums/viewtopic.php?f=2&t=18760 |
Author: | Thien [ Wed May 03, 2006 11:53 pm ] |
Post subject: | Handling with 13X7 wheels |
Hi all, Anyone running on 13X7 supalites? If so, how does it handle? How can the handling be improved? Thanks guys |
Author: | GTi_Mini [ Thu May 04, 2006 10:11 am ] |
i run 13x6's and the handling is awesome. you will here alot that 10" rims give best handling. i had 10's on my clubby and swapped to 12's and handling improved. on GTI mini i have the 13's and it runs rings around my clubby, although you have to match decent suspension to decent tread and rims |
Author: | Mini25 - UK [ Fri May 05, 2006 1:03 am ] |
i run 10s, handles awesome, but could be better |
Author: | Spaceboy [ Fri May 05, 2006 1:45 am ] |
10's and 12's have a nicer feel than 13's but the 13's usually have more grip |
Author: | Thien [ Sat May 06, 2006 3:11 pm ] |
Thanks guys, Doesn't the offset affect the handling as it has something to do with the wheels centreline? Cheers |
Author: | cush [ Sat May 06, 2006 4:45 pm ] |
10's look the business and do the business.... easy choice i say.. ![]() |
Author: | mutant mini [ Sat May 06, 2006 7:42 pm ] |
My husband and I both run on 13 x 7's on our 1993/1994 Rovers. We like the look so not really worried about the handling. John drives his everyday covering about 700 kms+ per week so he's obviously happy with the handling. Good luck with your choice. |
Author: | Zizzle [ Sun May 07, 2006 11:04 am ] |
TheMiniMan once said to me (I hope he doesn't mind the repost): Quote: k,,,13X7s look PHAT AS & i just love the look
![]() there`s chunks of work to do it really well & still have it low & handle etc otherwise you can just bung em on, fit the gorup 5 arches & be done with it sitting a little high & handling a bit like... well,,, a van with big wide wheels ![]() if you look on my web site in the projects page & click onto the "New Blew" you`ll notice that i had those wheels & flares fitted back then too, but i did a humungous amount of work to suspension, subframes, control arm pick up/pivot points etc etc etc cut the gaurds 1" & 3/4 etc etc etc &!!!!!!!!!!!!, those superlite 13s should really be called "super heavys", very very heavy & you will feel all that. then, after quite a few times on the wheel alignment machine getting it all sorted so it handled. It was awsome after all that tho, the best handling 13" wheeled mini i`ve ever driven. but like i said, chunks of work & i really wouldn`t recomend it to anyone if you were to pay to have all that done. I really don`t think i`ll ever bother to do it again, but thenagain... i do have this idea of a PHAT mini ute on 13x8s ![]() |
