It is currently Sun Jul 20, 2025 4:19 am
PostPosted: Sat May 06, 2006 3:05 pm
Hi Guys,
Bit off topic but need a little assistance - my partners Pulsar Q has developed a pin hole in the rad, as such it looses 500ml a day.I'm only putting the rad cap on one notch so it doesn't build up pressure, but of course it still leaks.
Being aluminum, I'm told the rad is too delicate to braze/weld whatever and a new core is the solution.
Does anyone have any suggestions for a glue or epoxy that can be successfully used?
PostPosted: Sat May 06, 2006 3:39 pm
Any good Radiator place should be able to mig weld it , with no trouble at all . I had a Radiator business many years ago , and we used to repair aluminium radiators quite a bit , however if it has one pinhole there may be more , the core could be on the way out , unless of course it was caused by a stone or something ....cheers
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sat May 06, 2006 4:53 pm
Fat80y wrote:
Hi Guys,
Put the pin back in..... ^_^
PostPosted: Sat May 06, 2006 6:34 pm
Hmm it was a rad palce that told it was too thin to weld!!!!
It's a brand new rad, one of the bolts holding the rad support panel came loose and rubbed a hole....
Might have to try a different rad shop...
PostPosted: Sat May 06, 2006 6:38 pm
malcom douglas on the world around us (incidently the shows have been re-running recently) told us a few years back to put ground pepper into the radiator.
it will float around until finding the leak to block it.
i highly do no recommend this as it could potentially block other parts of your engine too.
mind you, mal was driving a toyota landcruiser with big wheels and most probably big radiator cores and water channels.
Inconspicuously Conspicuous
PostPosted: Sat May 06, 2006 6:44 pm
i also remember seeing a product at my auto-place shelf
it says it stops radiator leaks and is in a small bottle about 50mL
and says "stop rad leak"
the liquid comes in two layers: clear blue and a thicker reddish that you shake
PostPosted: Sat May 06, 2006 6:47 pm
Yeah I was thinking I could dab some JB weld or equivalent on there...
PostPosted: Sat May 06, 2006 7:46 pm
I put half a little tin of white pepper in my old pulsar when it had a hole, drove around for probably 6months with no probs :)
..didnt seem to do any harm, drove for a few years with no probs after 8)
'78 LS 1275
I have used Wynns radiator stop leak on a few different cars with success but because it is a rub hole I would stick something on the outside.
JB weld or similar would be OK. I have patched some very bad radiators with epoxy ribbon with success (fan had chewed out a few fins because the engine moved going over a big jump)
PostPosted: Sun May 07, 2006 2:30 am
i ahve recently overcome a similar/same issue with my mini, i would pour the water in, and it would come straight out. go to supercheap or one of the other various assorted motoring stores, you can pick up this putty type stuff that you knead like blue-tack. its worked for me! i bought the cheapest one which was $7 and gave me more than enough putty for the job, i could probably fix 7 or 8 rads with the amount i used!
78 Leyland Mini - Prince
PostPosted: Sun May 07, 2006 2:34 am
Egg in the radiator?
Mythbusters did it and it worked.....so......yeh.
:D
PostPosted: Sun May 07, 2006 3:21 am
yeh egg in the raditor works have done it myself my sisters dodgy old astra had a plastic rad crack a egg in there with the engine off left it for a bit then started it up let it idle for a few minutes the egg cooks to the inside mostly good if its leaking from bottom of rad and it is only a temp fix will last a few days max we ended up finding an even dodgier old copper radiator eith holes in it and just soldered them up those plastic ones are crap
1978 NUGGET GOLD 1275 LS
PostPosted: Sun May 07, 2006 6:21 am
There is a product called quick steel about $15 a tube it is a 2 part epoxy but comes in 2 layers that need to be kneaded together until it heats up with the chemical reaction.
This stuff dries up in 10 minutes and is hard like steel.
Obviously the surface preparation is important so rub back the paint and clean around the pin hole.
I have used this stuff on a cracked head on my Gti and its still doing the job after 2 years :wink: and it is also used on some race Periphial Ported rotaries to blank off the factory inlet ports on the housings so the stuff certainly is durable :D
PostPosted: Sun May 07, 2006 6:22 am
PostPosted: Sun May 07, 2006 8:18 am
Go the EGG!!! Mythbusters r always right!!
