It is currently Mon Aug 04, 2025 1:32 am
 Post subject: Power Gains???
PostPosted: Thu May 11, 2006 11:15 pm
on monday Roundie (66 deluxe) goes in to get extractors... its a stocko 1100 and i was just wondering what gains i should get. not getting a dyno coz im on 1st year apprentace wages but what should i expect? not concentrating on power atm just getting her ready for the muster but when i collect some more $$$ what should be next on my list performance wise?
PostPosted: Thu May 11, 2006 11:19 pm
5HP maybe... not a whole lot just by fitting extractors......
It will be noticeable, however
PostPosted: Thu May 11, 2006 11:21 pm
5hp? thats not too bad concidering its a 10% increase from the shop figures of 50hp. by noticable you mean i will be able to beat the kids in my street on their deadly treddlys?
PostPosted: Thu May 11, 2006 11:26 pm
:lol: Depends how fast their little legs can peddle.
Better power all round will be noticed.
It will rev higher.
Sound nicer (if you are doing muffler and pipe too - limit this to 1.75" pipe MAX)
PostPosted: Thu May 11, 2006 11:37 pm
yeah i want to do zorst as well. why limit to 1.75??? will any bigger be too loud or a power loss due to lack of back pressure? how much will the larger exhaust set me back? might get a shinny centre exit muffler as well :D
PostPosted: Thu May 11, 2006 11:46 pm
Who is fitting the extractors?
The extractor-back system (including pipe, and bends required) should only cost around 400 dollars or so, with stainless muffler, tip(s) of choice, mounts of choice, etc.
From previous experiences, see if they can fit exhaust HANGERS, not the cotton reel mounts, which have a tendency to snap in the centre with spirited driving...
DEFINITELY don't go more than 1.75" on any standard motor... bigger you will go backwards - might as well have kept the stockie exhaust :lol:
Yes its due to the backpressure (you DO need it!)
PostPosted: Thu May 11, 2006 11:59 pm
to be honest with you willy i have no idea who is installing them for me! :? its a little gift from the old boy and will probably be done at a non-mini based garage so im guessing stock exhaust wll be on for a while. give it a month and i will have a scout around for someone who can find and fit the new system for me. is it difficult to source mini exhausts?
PostPosted: Fri May 12, 2006 12:02 am
what are you implying??? :wink:
PostPosted: Fri May 12, 2006 5:17 am
yes, a bigger exhaust will reduce power
and any place can do an exhaust for a mini, should be quite cheap too
PostPosted: Fri May 12, 2006 8:38 am
Resident Haemorrhoid
Dont take it personally
willy should of also mentioned that you can also run off the road and put the car onto its side after hitting an embankment whilst avoiding a car coming the other way when driving in a spirited manner :wink:
and if you have a big ass muffler fitted avoid driving over anything bigger than a 5c piece lying flat other wise you will fudge it as willy will testify to :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Fri May 12, 2006 9:11 am
A stocko 1100 wont be anywhere near 50bhp. :)
Expext a stocko 1100 to be at about 30 to 35bhp at the wheels.
A modded exhaust (Perry extractors, 2" pipe to a 4" cannon,) and a modded cam got me to 44bhp at the wheels.
No more Minis!......For now.
PostPosted: Fri May 12, 2006 9:18 am
I think you'll struggle to see 2hp gain..? you'll THINK it has alot more power though..
Leaving the stock carb and exhaust on will pretty much restrict you like it was before the extractors. you're just placing something that flows better in between to restrictions at each end. (carb and exhaust)
PostPosted: Fri May 12, 2006 10:04 am
If it's completely stock, it would have a 1.25" carby on it still. If it does, i'd put a 1.5" on it. Will be a cheap change and give you quite a bit better performance (if tuned right!). Will go very nicely with the extractors!
PostPosted: Fri May 12, 2006 9:21 pm
Hey willy,
Any backpressure is a power killer. Why would you want it at all ? Please explain. The reason you keep the pipe to a certain diameter is that each slug of compressed exhaust gas is speeding along the pipe and creating a low pressure zone behind it. That low pressure zone helps suck the next slug of gas along thereby helping to extract all the burnt gases from the cylinders. If you go too big you lose that effect, too small and restrictive(not just the pipe but anywhere else in the system) and you lose that effect. Back pressure would mean that you would be trying to stuff burnt gases back into the engine. There is a mirror bounce effect that travels all the way back along the system to the carby to help suck in more fuel but with the 3 exhaust ports on a mini you get a jumble that's hard (IF someone has managed to do it) to tune for. That's where tuned length exhausts come in on racing cars. They are usually shorter in length and exit out the side. I think for a mini the best is about 24" with a megaphone end but I have been known to be wrong, ask my wife.
smithy
PostPosted: Sat May 13, 2006 7:57 pm
ok so i talked to the old boy and he said i will be getting the extractors and a 2" exhaust all the way through... not sure on the exact facts but i've asked for it to be centre exit. will the 1/4" difference be much of a problem in the backpressure department?
