BABY SEAT IN A MINI
https://www.ausmini.com/forums/viewtopic.php?f=2&t=18882
Author:  MINIRO [ Sun May 07, 2006 3:11 pm ]
Post subject:  BABY SEAT IN A MINI
Ok peeps,
I was just wondering who has put a baby seat/capsule in there mini.
i was just wondering the best way about all the mounting points and so forth!!!
obviously the seat will have to go in the middle as i have 7x10s either side of the parcel shelf!!!!
If anybody has photos that would be great!!!
i need to put the seat in so that i can start coming on some mini cruises again, it has been about 2 years since my last cruise:(
Rohan
Author:  CPOCSM [ Sun May 07, 2006 3:14 pm ]
1977 minis had the child restraint fixing points in them. I have twin boys and carted them about in their baby seats - mind you they took up the entire back seat...lol
See the ambulance service - they seem to know where the places are that do the fixing points...I think there are certain rules and measurements involved so get some indy advice...
Good luck
Hooroo
Rob Forsyth
Miniot!!
Author:  MINIRO [ Sun May 07, 2006 3:36 pm ]
i should mention that i have a 1964 MK1
Rohan
Author:  gafmo [ Sun May 07, 2006 7:51 pm ]
Yep here's a Pic
Owen loves his drives in Morris I did get his seat profetionaly put in for us..just to be on the safe side..If you wish some pictires of the fixing points..I'll do a couple for ya Tomorrow Night :wink:
Author:  MINIRO [ Sun May 07, 2006 7:54 pm ]
Yeh that would be great!!!!
Rohan
Author:  gafmo [ Sun May 07, 2006 8:00 pm ]
No troubles...can't be stuffed getting under Morris tonight and I don't think you'l be do anything tonight anyway..as you can see we have put in on the passengerside..only for the eaz of geting in and out
Author:  MINIRO [ Sun May 07, 2006 8:03 pm ]
Yeh, i will have to put mine in the centre as i have 7x10s in the parcel shelf, so the anchor point won't fit!! (safely)
Rohan
Author:  gafmo [ Sun May 07, 2006 8:06 pm ]
6x9's here
Author:  MINIRO [ Sun May 07, 2006 8:14 pm ]
i have maybe 5mm either side of the speakers between the seat and the rear screen! :(
Rohan
Author:  CPOCSM [ Sun May 07, 2006 8:51 pm ]
Here are some piccies...
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00804.jpg[/img][/img]
The left bolt is for the passenger seat belt, the bolt on the right is the child restraint bolt(drivers side...)
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC00802.jpg[/img][/img]
This is the mount on the passengers side.
Hope this helps you - I think the plate steel can be put in the middle and all will be sweet.
Hooroo
Rob Forsyth
Miniot!!
Author:  Fat Boy Dave [ Mon May 08, 2006 4:35 pm ]
Mine looks just like Robs. Apparently it was a requirement for grey import compliance. Go figure.
Author:  Andy [ Mon May 08, 2006 5:20 pm ]
Is it legal if you install the mount point / seatbelt yourself?
Im faced with the same problem, have a 68, so no seatbelt or child restratint.
I'd be quite happy to install it myself, just want it to be legal if i get pulled over, or worse, have a crash.
Cheers :)
Author:  speedy [ Mon May 08, 2006 6:06 pm ]
Re: the install, check with your local authority. Regardless, I suggest you cough up the $30 or so and get it done properly, there are many tricks to installing them properly (most inertia seat belts require a special piece to lock the belt in place). A few years back a few blocks from my place a young couple got t-boned in a Corolla liftback entering Bunnerong Road, they hadn't installed the capsule properly, and the poor child was ejected through the rear window. It's not worth skimping on this, get a professional to do it.
Despite my Rover having the mounts fitted for Australian compliance, the local fitter couldn't fit any of better booster seats due to the belts securing the seat being too long for the mini. :x
Also, below is a useful piece of information from the NSW RTA on their recommended capsules that were tested to a program more rigorous than the Australian Standards. It makes for interesting reading.
http://www.rta.nsw.gov.au/roadsafety/do ... no4305.pdf
Author:  gafmo [ Sat May 13, 2006 10:34 pm ]
Sorry I have been slow putting pic's up but here they are
Was completed By Littles Restraints
Author:  gafmo [ Sat May 13, 2006 10:35 pm ]
Bugger I just reliased I should have got a pick from under the parcelsheelf, But I guess you get the idea :wink:
