It is currently Sat Jul 19, 2025 12:28 am
PostPosted: Mon May 08, 2006 12:02 am
I think i need to fix this...
am i looking at making replacements?
When fixing the floor pans do they come up the side aswell or is more metal needed
to patch up the sides?
any input is helpfull
cheers andrew
PostPosted: Mon May 08, 2006 2:24 am
The TIG
It looks like you will be busy for a while. I replaced a many panels on TurboOrangie last July-August. The floor panels I had sides on them that went part way up the exhaust tunnel on the floor on the medial side and upto the bottom of the door opening on the lateral side.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Mon May 08, 2006 8:25 am
Anton's "Jam" (Just another mini) has a good section on replacing the rear beaver panel - check that.
The Haynes Mini Restoration book has a few sections on replacing rusty horror stories - including a full floor pan - foot wells and inner and outer bottom sills.
There was a very recent thread here (with pics) about replacing a boot floor.
The main message is - cut and replace ONLY ONE panel at a time. Otherwise the mini shell will sag and lose structural integrity.
