It is currently Wed Aug 20, 2025 3:18 am
 Post subject: Rusty sills :(
PostPosted: Tue May 09, 2006 9:12 am
oh dear...
i saw a little hole, so i poked it with a screw driver...
after further investigation the rest of the sill is fairly thin, and there is a hole in the inner too(but apex panels are fine...)
i can patch the inner(outter is currently patched temporaray), but im thinking im best to just replace the whole outter sill, that way i can take it off and clean up/fishoil inside the cavity while im at it.
i then investigated the other side and its just as bad, only further along the car and the inner is okay.
SO: has anyone done a sill latley? do you just drill the spot welds along the seam and grind/drill the rest of the welds, clamp the new one on and plug weld along the seam? and then welt where ever else the orriginals are attached? (i havent investigated where they attatch)
 Post subject: Re: Rusty sills :(
PostPosted: Thu May 11, 2006 11:06 am
Well no one else has responded yet... I'm sure you've seen what I did but here goes....
I didn't use a commercial replacement panel, nor did I take the old one off up to the seam.
But I did do plug welds along the floor.
PostPosted: Thu May 11, 2006 11:38 am
yea, ive read through your resto thread(at least twice) :D
did you find that the plug welds were strong enough? because ive never looked under the outers before, im not sure how much streingth the outer provides?
thanks
Users browsing this forum: No registered users and 381 guests
