It is currently Wed Aug 20, 2025 3:20 am
 Post subject: damned radiator
PostPosted: Thu May 11, 2006 7:31 am
The other night I dropped my gf home not 30 mins from home water level checked only like 3 days beforehand, temp fine on the way there everything was going sweet. THEN on the way home I used the whole radiator full of water and had to stop lucky I keep a watchful eye on my gauges. Walked home got like a 2lite bottle of water and went back to the car several blocks away filled her up and then when i got it home the top and bottom hoses were cracked so i did chop n fix method seems to perfect again. However I wil buy new hoses and fit them wen I cna afford to have the car off the road.
PostPosted: Thu May 11, 2006 7:38 am
No , don't wait , get new hoses on it asap , how much did you spend rebuilding it ? Want to spend that again because you put off fitting new hoses for a few days ? 1275's are pretty close to the limit of cooling in standard trim with standard radiators so everything needs to be working right for them to go well . Do it this weekend if you can't do it earlier and carry a lot of water with you till you can change them as well , too much of a risk otherwise .
PostPosted: Thu May 11, 2006 8:50 am
it cost only in labour my labour for 30 minutes to detached and reattach the hoses after choping the split ends off. Temp superb now
PostPosted: Thu May 11, 2006 9:04 am
Nahh , I meant how much did it cost to rebuild the motor before you put it in , cooling is one of the things you can't be complacent with when you're running a 1275 .
PostPosted: Thu May 11, 2006 9:57 am
cough 3865 cough
PostPosted: Thu May 11, 2006 10:10 am
My opinion..If he cut of the cracked bit at the end and put the hose back on properly, i don't see any reason for him to be worried if it's keeping it cool fine now.
Sure get them replaced at your convenience, but if you ain't got a problem what's the rush? Just keep an eye on your temps, if you experience further problems, don't drive it until you change the hoses.
PostPosted: Thu May 11, 2006 10:17 am
thanks for the advice yeah the temp is fine now doesn't get past the 1/2 way mark and only goes slightly above in im in heavy traffic, once the car is movinbg itcool down to the 1/2 way mark (N).
thaks again guys
Users browsing this forum: No registered users and 413 guests
