It is currently Tue Aug 19, 2025 9:18 pm
 Post subject: dash pad
PostPosted: Tue May 09, 2006 7:01 pm
Hi all just wondering how to pull the top and bottom dash pad out, of a mini clubman.
Thanks.
PostPosted: Tue May 09, 2006 7:22 pm
The top pad is bolted thru the top rail, the front screen will need to be removed to allow it to come out, the bottom dash pad is glued to the lower rail, so care will be needed to remove it undamaged.
 Post subject: Dash Pad
PostPosted: Tue May 09, 2006 7:26 pm
Ok thanks i'll take it out when i put in a new roof lining.
PostPosted: Tue May 09, 2006 8:01 pm
i pulled mine out last weekend, it is worth mentioning that ther is about 1 million lil spring clips holding it on also. :shock:
PostPosted: Tue May 09, 2006 10:08 pm
resident alien
resident alien
I got mine out without taking the windscreen out.
PostPosted: Thu May 11, 2006 6:25 am
Was it hard to get out with the windscreen still in.
Thanks
PostPosted: Thu May 11, 2006 6:27 am
did it stay in one piece? or did it bend?
PostPosted: Thu May 11, 2006 6:02 pm
resident alien
resident alien
It took a little bit of work but eventually it came out.
Users browsing this forum: No registered users and 451 guests
