dash pad
https://www.ausmini.com/forums/viewtopic.php?f=2&t=18962
Author:  steve1965 [ Tue May 09, 2006 7:01 pm ]
Post subject:  dash pad
Hi all just wondering how to pull the top and bottom dash pad out, of a mini clubman.
Thanks.
Author:  The Toolman [ Tue May 09, 2006 7:22 pm ]
The top pad is bolted thru the top rail, the front screen will need to be removed to allow it to come out, the bottom dash pad is glued to the lower rail, so care will be needed to remove it undamaged.
Author:  steve1965 [ Tue May 09, 2006 7:26 pm ]
Post subject:  Dash Pad
Ok thanks i'll take it out when i put in a new roof lining.
Author:  jbeenz [ Tue May 09, 2006 8:01 pm ]
i pulled mine out last weekend, it is worth mentioning that ther is about 1 million lil spring clips holding it on also. :shock:
Author:  Marvin [ Tue May 09, 2006 10:08 pm ]
I got mine out without taking the windscreen out.
Author:  steve1965 [ Thu May 11, 2006 6:25 am ]
Was it hard to get out with the windscreen still in.
Thanks
Author:  jbeenz [ Thu May 11, 2006 6:27 am ]
did it stay in one piece? or did it bend?
Author:  Marvin [ Thu May 11, 2006 6:02 pm ]
It took a little bit of work but eventually it came out.
