TheMiniMan wrote:
But!!! all that said,,,"IF" you have changed out your rockers recently or had an engine rebuild by someone not very "Mini knowlegable" then maybe the rocker shaft has been changed to the later type where the oil feed hole is in the second pillar/post, these later shafts need the first 2 pillers/posts to have an oil feed/locj\k in them for oil to actually get to the rocker shaft.
Matt, now you may have confused him more than you think..
Ben,
Whether it's an antique (lock screw in 1st post) or late (lock screw in 2nd post) setup, the oil ALWAYS goes up the FIRST rocker post.
As Matt said, maybe the rocker shaft is worn out. Best way to see is take em off, slide the rocker away from the post and feel for wear in the shaft underneath.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
