Primary Gear end-float ....
https://www.ausmini.com/forums/viewtopic.php?f=2&t=19136
Author:  kazjim [ Fri May 12, 2006 4:16 pm ]
Post subject:  Primary Gear end-float ....
Hey all, just setting things up here ready for assembly ....
I've got three primary gears, three "front" bushes (One closest to the engine) about 30 lock rings and "C" washers ...
no matter how i mix and match, i cant get less than about 0.018" end-float...
Manual calls for about 0.006" and the Miniman reackons 0.005" is the go ....
i MIGHT have some more front bushes around here somewhere, but other than that, whats the answer ?
I Know too LITTLE End float is disastrous for gear-changing, but I'm assuming that too much will allow oil to escape and possibly lead to too much movement and eventual failure ....
Anyone got any ideas ?
J
Author:  TheMiniMan [ Fri May 12, 2006 4:41 pm ]
Hey Jim Bob,,,i make the front thrust washers up to size,,,tell me what you need & ...well...hey presto!!!
Magically one will arrive in your letter box
Author:  kazjim [ Fri May 12, 2006 4:43 pm ]
I'll be getting a few more primaries and bushes to try out over the weekend, I'll drop you a PM after that Matt !!
J
Author:  TheMiniMan [ Fri May 12, 2006 4:50 pm ]
yeah no worries man, just pick the best of what you have,,,throw it all in there,,,measure what gap you have & then measure what thrust you have used for me, so then i can add what you need to end up with what you need
if that makes any sense at all ???????
Author:  MiNi MuLiShA [ Fri May 12, 2006 6:30 pm ]
get out a knife sharpening stone (grindstone)
add ATF or singer oil, and away you go ;)
-Cam :lol:
Author:  AJ [ Fri May 12, 2006 7:13 pm ]
Have you tried a thinner housing gasket ?? they come in about 4 thicknesses ...cheers
Author:  TheMiniMan [ Fri May 12, 2006 7:21 pm ]
Aj,,,the primary gear has nothing to do with the housing or it`s gasket
you`re thinking of the "Idler" gear end float
wrong thread
Author:  AJ [ Fri May 12, 2006 7:56 pm ]
Ah yes I was too , thx MiniMan , I stand corrected :oops:
Author:  TheMiniMan [ Fri May 12, 2006 8:06 pm ]
nah,,,take a seat mate,,,save back pain :-)
