Worst job EVER!!!! https://www.ausmini.com/forums/viewtopic.php?f=2&t=19150 |
Page 1 of 2 |
Author: | Qship [ Fri May 12, 2006 9:40 pm ] |
Post subject: | Worst job EVER!!!! |
I have a new worst job EVER! Clutch and brake master cylinders. I could have cut the whole front of the car off it was so frustrating. I couldn't get one of the pins out under the dash on the pedal box. Theres only so much time you can spend, on your back, on the floor, under the dash before you grab the grinder and cut the bastard out. Yeah! Me "one", mini "none" Has anyone else got a WORST JOB EVER? |
Author: | Mini25 - UK [ Fri May 12, 2006 9:58 pm ] |
man i thought that job was hard, and i got it out in the end!! must have been a b***h if u had to grind it off |
Author: | Hagar [ Fri May 12, 2006 9:59 pm ] |
Water pump bypass hose, without removing the pump/head... ...pump'll be comin' off next time |
Author: | The Toolman [ Fri May 12, 2006 10:04 pm ] |
Two things I'm not rushing to do again are to reinstall the wiper wheel boxes and those metal tubes and to put 1/4 vent window assemblies back in the doors, but I've found most things on the mini are a bitch to do, due to lack of room, I guess having big hands doesn't help much either. |
Author: | Spaceboy [ Fri May 12, 2006 10:11 pm ] |
i found that job pretty easy, doing the pedal box thing with the master cyls, you need a torch shining up so you can see, and i did it on all fours resting on my elbows |
Author: | andbat [ Fri May 12, 2006 10:18 pm ] |
oh i remeber doing that one. that job was a bit of a pain, made it easier the fact that i had the seats out at the time. worst part was i lost the pin and had to find a replacement, it is still somewhere up behind the wheel somewhere. (oh and i found a shelf full of little rocks dose anyone know where they may have come from?) |
Author: | Lillee [ Fri May 12, 2006 10:30 pm ] |
Try replacing the front right brake hose on a roundnose without cutting a hole in wheel arc... If the clutch pin is a b***h then the brake hose is a MEGA B***H! ![]() |
Author: | meeni [ Fri May 12, 2006 10:36 pm ] |
yer what you said 68deluxe, the clevis pins for the brake and clutch are ok on my car, only takes two minutes to change them. |
Author: | h0nk [ Fri May 12, 2006 11:30 pm ] |
When the front has been cut off the car, and you've got no seats, it's not too hard to get the master cylinders off ![]() |
Author: | WhoDat [ Sat May 13, 2006 12:19 am ] |
Clevis pins can be a bugger if they are well worn like mine were. I gave up in the end by pulling the circlip on the master cylinder and pulling out the guts of it so i could take out the pedal box with the clevis pin and piston still attached. Took it down to the bench and had it out one well aimed blow with a punch and BFH. Tip: New pins and deburred holes make life a piece of cake now. |
Author: | Mini25 - UK [ Sat May 13, 2006 1:05 am ] |
to make life easier next time, i use one of these http://www.twf8.ws/new/tech/car/xray/xb ... -5-019.jpg the silver bit in the middle, they are a 'body clip' for a remote contolled car, and u can use one instead of one of these clevis pins and make life a lot easier |
Author: | justminis [ Sat May 13, 2006 8:32 am ] |
The brake and clutch m/cylinder clevis pins in a Moke where the PO replaced the clevis pins with 5/16" nut and bolt, that rusted over time and the corners on the nuts and bolts turned off. These mongrels were tight right to the very end of the bolt, you know the type. I figure my revenge is to put them back in for the next owner ![]() |
Author: | awdmoke [ Sat May 13, 2006 10:33 am ] |
PO had re-used the bent split pin on my clutch master, which jammed & I spent 2 hours trying to get it out (sore back later) then I thought about chopping it off whith the grinder & remembered I had a dremel - 5 mins later I had the pin out ![]() |
Author: | monrel [ Sat May 13, 2006 2:09 pm ] |
Post subject: | body clip |
Mini25 - UK wrote: the silver bit in the middle, they are a 'body clip' for a remote contolled car, and u can use one instead of one of these clevis pins and make life a lot easier
Hey!! I use those too! I've found that in some hardware stores, they are also called "R-clips, or "humpback" clips |
Author: | doogie [ Sat May 13, 2006 2:15 pm ] |
Go to Supercheap & spend the 10 ish dollars on a long set of pointy nosed pleirs, under 5 mins to get the pins out that way. Doogie |
