is it the cv's? https://www.ausmini.com/forums/viewtopic.php?f=2&t=19168 |
Author: | 64morris [ Sat May 13, 2006 5:22 pm ] |
Post subject: | is it the cv's? |
whenever i drive my mini there is this horrible knocking at the firewall when i am driving in a straight line with low throttle and when i turn the wheels to any degree. this problem is making me sick every time i drive the car. i am thinking it is the cv's but would like to find out for sure, also if this is the problem how hard are they to replace? also i have cooper discs on the front if that makes any difference. thanks in advance. |
Author: | Fat80y [ Sat May 13, 2006 5:30 pm ] |
Do you have hardy spice uj's? Or the dreaded rubber coupling? I often have problems with these joints and poorly made extractors rubbing. CV's shouldn't make a noise in a straight line, unless they are really shot. Other options are collapsed wheel bearing (but you'd really notice that) or perhaps loose - check the castellated nuts for tightness on the end of the cv's |
Author: | feralsprint [ Sat May 13, 2006 5:32 pm ] |
Doesn't sound like CVs more likely the result of a broken engine mount or steady but without knowing all the ins and outs of your car is very hard to tell, why not get someone like the miniman have a look at it to be sure, it may be something really simple like a broken exhaust mount. CV joints do not usually make noises in a straight line and if they do its terminal ![]() Jon |
