Removing the Granule Canister
https://www.ausmini.com/forums/viewtopic.php?f=2&t=19169
Author:  Gerard [ Sat May 13, 2006 6:10 pm ]
Post subject:  Removing the Granule Canister
Hi all
I am wanting to remove the black granule fuel return system out of the car ...... can i run the overflow from the carbie back to the fume pipe that runs back to the fuel tank?
Is this safe?
Any other options?
I want the space for a new washer bottle :D :D :D
Cheers Gerard
Author:  Matt [ Sat May 13, 2006 7:40 pm ]
I've got a late model carby on an early model mini, i just blocked the overflow off.
hope it helps :?
Author:  Gerard [ Sat May 13, 2006 8:38 pm ]
mate is blocking it off safe?
I have a HIF44 on my car....
Author:  Jules [ Sun May 14, 2006 11:49 pm ]
Overflow from the carby should be left open to atmosphere, but you must run a hose from it to somewhere away from sources of ignition (don't just leave it hanging above the exhaust...).
Author:  Mike_Byron [ Mon May 15, 2006 10:21 am ]
Treat all fuel leaks as being dangerous so, like stated above, just run the return line away from potentially explosive areas.
having said that though - I have seen fuel on manifolds many times over the years. It almost never catchs fire. It tends to just evaporate off instead. Most older SU carbies do leak some petrol out the choke and spindles in any case.
But what is very dangerous and the point of my comments - is a leaking exhaust at the flange and sparks - such as high tension leads that are dirty and breaking down. At some stage - after dark - go out, start the mini, lift the bonnet and see if you have sparks running all over your ignition leads. If you do - then get a new set.
Author:  68matic [ Mon May 15, 2006 11:18 am ]
grease +oil + dust soaked in fuel keeps alight nicely :wink:
Author:  Gerard [ Mon May 15, 2006 11:22 am ]
so does that crappy old Jute underlay under the carpet - smolders beautifully...... needless to say i did not use it when i changed the carpet :shock: :shock: :shock:
