Aliens
https://www.ausmini.com/forums/viewtopic.php?f=2&t=19178
Author:  Dixon Bainbridge [ Sat May 13, 2006 10:15 pm ]
Post subject:  Aliens
Howdy all, I have another problem with the ol' mini.
I dunno if this is a common problem for the mini, but whenever I make a mild left turn there is a strange noise, which sounds like an alien from outta space, coming from the rear of the car.
Has anybody else had this problem before?
Author:  Harley [ Sat May 13, 2006 10:48 pm ]
Hmmm, now if it was a leprechaun or a ghost in the engine bay I might be able to help, but sorry, I don't do aliens. :D
Good luck.
Author:  HPDesign [ Sun May 14, 2006 1:58 am ]
have you checked your rear left and right wheel bearings?
if it's a whurring or high pitched vibration it's a good place to start.
jach the caar up at the rear and check for free play sideways with the rear wheels on. no noise or movment is good
Author:  adeee [ Sun May 14, 2006 1:49 pm ]
minis also have gremlins, but they can be atrributed to the prince of darkness. He only has power over electrical issues though.
Author:  Dixon Bainbridge [ Sun May 14, 2006 10:50 pm ]
Hehe, thanks for the advice about the bearings. I checked the back wheels and there seems to be a bit too much play, so I will see how to change them over in the manual and hopefully no more invasions.
But the aliens were good for scaring mates when I took them for a drive.
Author:  drmini in aust [ Sun May 14, 2006 11:05 pm ]
Note the LR hub nut is LEFT HAND thread... if you are wondering why the bugger won't undo... :lol:
Author:  HPDesign [ Mon May 15, 2006 1:31 pm ]
if it matters too you the taper bearings are better than the roller type they last a bit longer. considering it's not the most "clean" fun you can have with your mini it might be worth not having to do again for a while
Author:  Dixon Bainbridge [ Mon May 15, 2006 5:41 pm ]
Thanks for the tips. With the thread, I found that out a couple of weeks ago when I put just about all my effort into undoing it.
