How hard is it too?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=19214
Author:  mooman10_0 [ Mon May 15, 2006 10:43 am ]
Post subject:  How hard is it too?
Change to high lows on a van trailer?
Author:  Stuwey [ Mon May 15, 2006 10:55 am ]
Should be simple as. Can you turn it upside down and work on it that way :?: :lol:
Author:  Spaceboy [ Mon May 15, 2006 12:32 pm ]
unbolt the shockers from inside the trailer, jack the trailer up, remove the wheels, push the trailing arm down, seperate the cones from the trumpets and remove
reinstall with hi-los where the trumpet goes
Author:  mooman10_0 [ Mon May 15, 2006 1:30 pm ]
Will fitting hilos enable me to make the van sit lower?
Author:  Spaceboy [ Mon May 15, 2006 1:33 pm ]
yeah
Author:  jbeenz [ Mon May 15, 2006 2:40 pm ]
yea, but you will want shorter shocks if u want to go more than about 1/2 - 1" lower? i think? or the knuckle joints will try to pop out, or make funny noises. i dunno about everyone else, but in my car, i fitted spax adjustables (lowered) and set the hi-lo's so the shocks are mid-stroke at rest. no probs that dropped it to the sam height as my saggy front end.
Author:  Angusdog [ Tue May 16, 2006 7:29 am ]
If you buy a set of hi-los, you'll end up with spare bits for the front end. Why not machine a little from the trumpets or fit saloon trumpets? Cheaper and no wastage - it's only a trailer. You just need to know the ratio of amount removed vs subsequent drop in ride height.
Author:  mooman10_0 [ Tue May 16, 2006 8:52 am ]
Can I adjust the van rideheight just by changing the shocks?
Author:  Angusdog [ Tue May 16, 2006 9:01 am ]
No. Ride height is a function of how compressable the rubber cones are, the length of the aluminium trumpets and the trailing arm. Do a search on lowering a mini. You can remove the end of the trumpet and file or machine a little from the end, refit the end and reinstall. But the amount removed is a lot more than the drop attained.
