It is currently Fri Jul 18, 2025 12:07 am
PostPosted: Fri May 19, 2006 9:37 am
I have a small journal 1100's crank that I just pulled out of a motor that was running but over due for a rebuild. How much is the going price for crack testing and machineing?
It is currently .010 under size on mains and big ends but I think it may need to go .020 as there are a couple of marks. Is it OK to go .020 on these cranks?
Also a quick one on thrust washers, it had a set of .030 over on the front side (balancer end) and a standard size set on the other side (clutch end) is this normal or should they be the size on both sides?
Thanks in advance.
Pete
PostPosted: Fri May 19, 2006 12:55 pm
you could take it to our mate Spiro at Seven Hills..just around the corner from bith Dr and myself...around $120 from memory which included grinding and or polishing
PostPosted: Fri May 19, 2006 7:31 pm
Have you got his contact details?
Pete
PostPosted: Fri May 19, 2006 8:06 pm
St George Crankshafts, in Bearing Rd Seven Hills.
Right outside CB Performance Engines shop.
Sorry I don't have the number...
Deluxe_68, you probably had an 1100S crank in an S block, there is 1/32" difference in centre main journal width.
Don't throw those +.030" washers away, they are NLA now unless you get somebody to make `em up special.
re the journal sizes, yes .020"/.020" is fine.
PostPosted: Fri May 19, 2006 8:21 pm
Doc, yes it is a 1100's crank in a 'S' block.
Are the thrust washers supposed to be the same both side or does it not matter?
Pete
PostPosted: Fri May 19, 2006 8:46 pm
2/9 Bearing Road (Figures) Seven Hills 9674 1201..Ask you should get Spiro straight away..he should be working tomorrow morning also :wink:
PostPosted: Fri May 19, 2006 8:54 pm
Pete
Well I usually make them equal, but provided it clears OK 30 on one side works OK.
I'd put the thick one towards flywheel end, but it really won't matter.
PostPosted: Fri May 19, 2006 9:04 pm
Thank every one for your help.
Pete
