**HELP** doing up ball joints https://www.ausmini.com/forums/viewtopic.php?f=2&t=19352 |
Author: | arpy69 [ Fri May 19, 2006 3:09 pm ] |
Post subject: | **HELP** doing up ball joints |
Hi Guys Any tips on how to get the ball joint housing done up properly. I know it needs to be 72ftlb (previous post by the Doc) but I don't have a vice (apart from alcohol ![]() ![]() Any tips very gratefully received. Cheers Rick |
Author: | Mini Mad [ Fri May 19, 2006 3:36 pm ] |
Don't know why you'd want to use a vice..? to clamp it? ![]() I assume you are using a torque wrench? try using a breaker bar on the end ( a piece of pipe or something to help you persuade it ![]() |
Author: | arpy69 [ Fri May 19, 2006 3:47 pm ] |
Hi miniMad. i hvae a torque wrench that is long enough to do up to that torque, the problem is holding the bloody hub to counter the torque wrench ![]() If I had a vice I would clamp the hub in it and then use the torque wrench on it to tighten the ball joint, but I don't ![]() |
Author: | Spaceboy [ Fri May 19, 2006 6:13 pm ] |
ahh yep i know what u mean i had the same problem, but i did manage to get a vice from somewhere, and i also wedged the spare tyre under it |
