It is currently Wed Jul 23, 2025 10:06 am
PostPosted: Sat May 20, 2006 10:47 pm
These were both fine until the motor transplant and now I have no feel in the clutch pedal.
I have tried to bleed the slave cylinder but soon as the pedal is released the pressure is gone and the pedal is soft again.
I have noticed no leaks and by observation when the clutch pedal is pumped a few times to build up enough pressure and travel in the slave cylinder whislt holding the clutch depressed I can see the slave cylinder lose pressure and move back in slowly.
Which one is the possible culprit? (please be slave ).
What other signs or bleeding procedures can help to identify the problem?
PostPosted: Sat May 20, 2006 10:53 pm
Slow-Po
My money is on the slave. 8)
Any fluid around the clutch pedal?
PostPosted: Sat May 20, 2006 10:56 pm
Nope dry feet here, but neither of them are leaking :?
PostPosted: Sat May 20, 2006 11:02 pm
Yeah, sure :roll:
Lie on your back & stick your hand up onto the rod linking the clutch pedal to the master cylinder. Odds on you'll find it leaking.
Then the fun really begins!
PostPosted: Sat May 20, 2006 11:22 pm
id say if it was fine befor the moto transplant that the littlestop screw in the clutch cover that pushes up against the clutch arm is not adjusted right, if you wind it out it raises the friction point, if wound in soft clutch
PostPosted: Sun May 21, 2006 8:37 am
I hear you but I should still be able to get enough extension on the slave so I can at least get it into gear.
Yeah, sure Rolling Eyes
I can even get my big hands up there :shock: without removing the ventilation duct.
So far it feels dry. I will try again till I reach the link for the master cylinder :x
PostPosted: Sun May 21, 2006 8:40 am
Slow-Po
Sorry, first question I should have asked is is it losing fluid?
BTW, if the pedal is dry, then its likely not to be the master giving you the problem.
PostPosted: Sun May 21, 2006 8:43 am
This is amazing..I see this happening so many times..I put a extended shaft in my Slave and that fixed it but also check firt if the circlip is in thier if so take it out and try it again
PostPosted: Sun May 21, 2006 4:24 pm
i having nothing to add but to point out
"I put a(n) extended shaft in my Slave" :D
a girlfriend would be cheaper
