what are these??
https://www.ausmini.com/forums/viewtopic.php?f=2&t=19437
Page 1 of 2
Author:  falcon_princess [ Mon May 22, 2006 9:07 am ]
Post subject:  what are these??
Hi, just wondering what these are?? the stick bit, i know the round things are the things that the wheels go on..
i anyone has one lying around and dont want it i would be so grateful if you would sell it to me, if you live in sydney area ill pick it up not ill pay for postage.. thank you so much :)
Author:  Mike_Byron [ Mon May 22, 2006 9:24 am ]
Can you please have another go at asking what it is you are asking about. I have lots of bits but Ii am a little confused as to what stick bits you mean ????
Author:  awdmoke [ Mon May 22, 2006 9:24 am ]
Driveshafts (minis came with 3 different types)
<edit> I grew up with 3 sisters, so I'm used to deciphering vague mechanical descriptions :lol:
Author:  falcon_princess [ Mon May 22, 2006 9:28 am ]
Post subject:  yes thats it...
:D hahaha, :D thats hilarious, i thought i was quite clear :? .. thanks for your help, yes thats what i need a drive shaft, but just 1...
it would be fantastic if you could be of assistance. :D
thanks
Author:  Mike_Byron [ Mon May 22, 2006 9:37 am ]
Okay - only had one sister and she learnt boy talk.
The axles - as pointed out come in three types. If you have a clubman then it most probably has the pot joint type - two black steel cylinders with six grooves on the inside.
The disk brake assembly you have is off a Cooper S and will not fit. However, all is not lost.
The axles fit into the constant velocity joint that is next to the disck brake assay. ALL axles are interchangable. Your original clubbie axles will fit into the disck brake assay.
Take your old brake assays - both clubbie and cooper types - to a brake or suspension place and ask them to change the axles over. They do just bang off but proper mechanics have a tool that makes it just that much easier.
Then just reassemble making sure thatr all the six balls on each side fit properly into the black cylinder thingo sticking out of the gearbox on each side
Author:  simon k [ Mon May 22, 2006 9:37 am ]
yeah, perfectly clear to me too - 2 sisters, 3 daughters....
Author:  doogie [ Mon May 22, 2006 9:37 am ]
You stole my photo!!!!!, those disc brakes are fitted snuggly to my van now.
Doogie
Author:  Mike_Byron [ Mon May 22, 2006 9:39 am ]
Ummm.. why do you need one ?????
Author:  falcon_princess [ Mon May 22, 2006 9:48 am ]
lol, im sorry to have stolen your photo '2 S's & a clubman' i saw it and i thought oh my gosh thats what i need, id been looking on google but when i typed the "stick thingy that atatches to the motor and the wheel" It didnt come up with anything remotely what i was looking for.....
well i only need 1 drive shaft because i have 2 clubmans a yellow one which was a rolling shell with the motor and the front sub frame apart from it.. then i got the one i have now and needed the motor but the sub frame was already on this car, therefore i had to get the motor off the subframe in order to sell the yellow car with its subframe... so i have to take the push rod ends out of the subframe and the motor and one went with the guy that bought the yellow mini, i didnt realise till now and i sold it about 6 months ago.. so that was a bugger..
maybe if i get 2 off you then i can chuck mine, save the hassle if mine isnt going to go with the one i buy..
and i need a clubman one, ill take a photo of the one that i have.. are they supposed to match??
thanks for your help guys.. its my first project car and ive done it all myself and need all the help i can get..
Author:  Mike_Byron [ Mon May 22, 2006 9:52 am ]
*lol* I still can only read boy talk. Yes please post a photo of what you have and what you actually need. There are three types of axles.
Author:  falcon_princess [ Mon May 22, 2006 10:24 am ]
this is the driveshaft...
if it isnt clear what type it is ill ask my dad when i see him tonight..
oops sorry the photos are so damn big.. lol
Author:  awdmoke [ Mon May 22, 2006 10:39 am ]
See the ball bearings on the end?
That means it is a "Pot type" (standard on most clubbies).
Also one of the most durable types :)
Author:  Mike_Byron [ Mon May 22, 2006 10:39 am ]
Okay the one in the photo is a pot joint type. They come in two lengths. A short obne and a longer one. Both the short one and the long one are needed on any mini.
There is a difference between the diameter of the splines of the constant velocity joint (CVJ) where it bolts to the "round thingy that the wheels bolt to". This is the difference between CVJ's disk brakes and drum brakes. The disk brakes have a much larger spline.
Either way - as I said earlier all axles can be changed from CVJ to another type of CVJ. I do have axles (with CVJ) to suit clubbie drum brakes but not for disk brakes.
Author:  _666_ [ Mon May 22, 2006 10:51 am ]
are you talking bout the cable ties ? lol
Author:  HPDesign [ Mon May 22, 2006 10:53 am ]
now :D that looks like a clean job. :D Maybe that is the original grease by the looks...
you have the CV (Constant Velocity Joint) Type. They look like ball bearings packed in grease but they are solid (not like their rotating bearing mates)
from memory one is a bit longer than the other as it has further to go from the gearbox to the wheel.
These shaft's are in 3 pieces
-THE SHAFT- just the solid metal bar
-The CV'S x2 an inner and outer CV joint
the outer end is the end you bolt to the wheel with the tread and splines on it and the inner is the one that goes into the gearbox.
the outers are different for drum and disk brakes. i.e: drum brakes go with drum CV, disk brakes go with disk CV's
the inner CV's are all the same from memory.
Hope this helps :D
P.S. do yourself a favour and grab a workshop manual (Hayes brand if possible) you will find it the best resource to DIY keeping your mini on the road, and yourself safe
