It is currently Sat Aug 02, 2025 9:49 pm
 Post subject: metal "covers" on seams
PostPosted: Mon May 22, 2006 5:33 pm
how does one remove these? Is it just a matter of riping the ba$tards off..? I have rust developing under neath the passenger seam on Toby and need to get the cover off to fix it before it gets worse.
once its off, new ones can be bought cant they..???
 Post subject: Sikoflex
PostPosted: Mon May 22, 2006 5:50 pm
They have a spot of braze/weld at the top and bottom.....carefully grind through these (without going too deep and into the panel)....dremel is good if you have one :idea:
Then they just should pull away....be careful because there are clips underneath .....so work from one end...feeling for the clips.
Replacements can be glued on with sikaflex....search on that :idea:
PostPosted: Mon May 22, 2006 7:09 pm
Yes you can still buy new, Karcraft sells them. $16.20 each.
PostPosted: Mon May 22, 2006 9:41 pm
Can you buy new ones in chrome?
Justa thought!
Take it easy, & if it's easy take it twice!!
PostPosted: Mon May 22, 2006 9:44 pm
havn't seen them in chrome, but i'm sure you could get them chromed.
I'm in the process of getting new covers put on mine, one of the ones i got (the Rear right) is slightly different, but the bloke at mini spares centre said that there the only ones available, is this true?
ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
Users browsing this forum: fuzzy-hair-man and 94 guests
