Mike_Byron wrote:
It will cost you about $250 to have the head reconditioned - that is a chemical clean, new guides, one new valve, a head skim (to make sure its perfectly flat) and have all the valves reseated. For about an extra $100 you can have hardened exhaust valve seats fitted which will allow you to run unleaded petrol.
Your machinist may advise that one or more valve may need replacing and valves are less than $20 each for standard and normal sized valves.
The costs may vary from place to place but the above is a pretty good guide. An option is to go to a wreckers - or a mate- and but a second hand head that looks good. You could take it to a machinist and have it pressure tested and skimmed (about $50) and just stick it on. Chances are it will be a reasonable quick fix. I am sure any number of ausmini will sell you a small bore head for a very reasonable cost. If your engine is large bore then the head cost is very different.
Now, exhaust valves take an enormous amount of heat and stress and it doesn't need much of a gap between the seat and the valve for super hot gases to pour past under compression. Once that starts the valve will very quickly burn. The cause may be crap built up on the valve seat, valve not closing properly, a valve sticking slightly open in the valve guide or the valve simply starting to break up due to age.
Haha I got mine for free and it was all done by the engine recoers (work experience)
monkey pm me if you are interested int he head I can sell you it if you are interested
Pat
