not fair smokey mini
https://www.ausmini.com/forums/viewtopic.php?f=2&t=19585
Page 1 of 2
Author:  clubby123 [ Thu May 25, 2006 9:47 pm ]
Post subject:  not fair smokey mini
my mini is blowing smoke like no tomorrow what could of happened
Author:  Hanra [ Thu May 25, 2006 9:47 pm ]
Filled er up with diesel is my guess!
Author:  marcsvenson [ Thu May 25, 2006 9:50 pm ]
what condition is the head in and what colour smoke
black or blue or white
Author:  andbat [ Thu May 25, 2006 9:58 pm ]
done any spirited driving lately?
Author:  clubmn [ Thu May 25, 2006 10:17 pm ]
Post subject:  mm1275
ill sell you a complete mini clubman with recepts to a engine rebuild ($4000).
For 2k. That may fix ur problem
Author:  bmx_bandit [ Thu May 25, 2006 10:20 pm ]
ill beat that!!! $600 for my clubby. bolt on new box, good as new :lol:
Author:  clubmn [ Thu May 25, 2006 10:37 pm ]
If your clubbies engine has 4k worth of recepts then true. you beat me.... If it doesnt then 2km down the road the engine could start blowing smoke.....
A complete engine and box rebuild should last another 80,000M
Author:  willy [ Thu May 25, 2006 10:42 pm ]
Want me to drive your four-thousand dollar motor and have it blow up in 2km?
Where there's a Will there's a way.
Author:  bmx_bandit [ Thu May 25, 2006 10:43 pm ]
:oops: ok i miss read your post... you win!!! :wink: but really ben u want my clubby or u just gonna bits it tomorrow when u come up?
Author:  harvey69 [ Thu May 25, 2006 10:46 pm ]
im abit annoyed with the smoke from my clubby..... i just thought it was bekuz of a destroyed valve..... so i went and got the head rebuilt and its now blowing even more smoke....?
ahhh what the...... so im not happy
Author:  1360 LS [ Fri May 26, 2006 8:06 am ]
I had my Clubby bow more than excess smoke I burnt out an entire cylinder. smoke everywhere and I drove it home for hours before i cud get it fixed and to bore the engine and everything a ffew things as well to it but cost just under $4K to do that wa for a 1275 though. bes t of luck
Author:  sports850 [ Fri May 26, 2006 8:22 am ]
Post subject:  Re: not fair smokey mini
There really are a lot of things that could cause this , what colour is the smoke ? What fluid's if any are dropping (check oil and coolant) . As a very quick test leave the car idling and with a pair of insulated pliars pull a plug lead off at a time , if it runs a bit rougher each time then one cylinder shouldn't have a major problem alone , if pulling the lead off makes the motor sound rougher on all but one and the other one doesn't change the motor's sound then that one may have a problem . Beg/borrow/buy a compression tester and see what that tells you . How long since the motors been rebuilt ? Does it smoke all the time , only under acceleration , only on deceleration or coasting down hill ?
Author:  JAM_IT [ Fri May 26, 2006 8:42 am ]
a sudden change from no smoke?
if so, cracked head, or head gasket.
Author:  Zizzle [ Fri May 26, 2006 10:06 am ]
Whack the head off and have look see. You've only got a few weeks to mini muster no?
Author:  bmx_bandit [ Fri May 26, 2006 1:48 pm ]
grey smoke, has the usuall smoke but just last night there was a s#!t load when i would take off, is running fine but yea smoking alot
