I have rebuilt a set of metro calipers where the pistons are smaller (less effort for fitting), however heres what I did:
1. Get some rubber grease from a brake place or the likes.
2. Cover the fluid seal in grease all over and fit to caliper, and do the same with the dust seal and its retaner.
3. Cover the piston in the rubber grease, the more there is the easier the job, and push into the calliper.
I was able to fit the pistons by hand, but a G-clamp would be of use too.
Just make sure you clamp the middle of the piston so it remains square to the bore.
Good luck.
