It is currently Mon Aug 04, 2025 8:28 am
PostPosted: Sat May 27, 2006 11:35 pm
Ok well i'm not trying to be a cheap arse.. but I came across this thread:
http://board.moparts.org/ubbthreads/sho ... art=1&vc=1
If you scroll down to 69chargeryeehaa's post he has links to car's he's painted with a roller, and they actually look pretty good :shock:. Just wondering if anyone has tried this method, what degrees of success did they have?
Heres some of his cars if you can't be bothered finding it:
PostPosted: Sun May 28, 2006 12:32 am
I'm sure you could make a nice job of it :roll:
PostPosted: Sun May 28, 2006 1:44 am
Commonly seen on VW Kombis, and usually painted with Wattyl Mission Brown!
PostPosted: Sun May 28, 2006 2:08 am
that is surprisingly a pretty good job if you ask me!
PostPosted: Sun May 28, 2006 3:25 am
Die Die Die!!
looks alright... but i wouldnt go that cheap lol
PostPosted: Sun May 28, 2006 8:35 am
i guess if you rolled it on thick enough and then sanded with like 400, 800, 1000 etc you may get quite a nice finish, huge wase of paint though....at least itd fill the sand marks :)
loving that charger!
PostPosted: Sun May 28, 2006 8:53 am
Yeah i suppose it would work, but as said, you would use alot more paint, and it'd require alot of sanding afterwards to get a good smooth finish.....
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Sun May 28, 2006 3:22 pm
x2
I might have to try it on something (other than one of my cars) to see if it's worth a crap.
PostPosted: Sun May 28, 2006 8:06 pm
alex i say go for it. if you dont have the $$ or room for a gun and compressor
i painted the interior of my car with a roller and it turned up very nice and shiny.
1) roller is one which is about 8cm long. small pored foam. not that raggy stuff you see that paint houses. i got mine from my local hardware store. red handle.
2) plenty of thinner
3) if too thick, it sticks like honey and forms flossy stuff as you roll
4) no chance for runs :wink:
if you Eff it up you can always sand it back
Inconspicuously Conspicuous
PostPosted: Sun May 28, 2006 8:13 pm
This car may not have been painted this way but, Rolls royces (and probably other old cars) used to be painted by hand. I think it was a certain kind of paint brushed (or i suppose rolled) onto a heated panel.
The heat would somehow take all the brush marks out of the paint, leaving it no worse than the modern day paintjob.
Take it easy, & if it's easy take it twice!!
PostPosted: Sun May 28, 2006 8:20 pm
When using a brush heat the paint as well. :wink:
PostPosted: Sun May 28, 2006 9:10 pm
awdmoke wrote:
paint your car with smooth rollers and warm loving paint man :D . peace is in the petrol. flower power all the way.
(ok i'm bored :P )
PostPosted: Sun May 28, 2006 9:17 pm
I remember seeing that a while back and at the time thinking something sucked about it. I didnt read it again, as i couldnt be stuffed, but I think the thing that i thought 'sucked' was probably just the time consumed when doing it that way. That being said, I have done similar things with a roller, only not on a car and with different paint.
With the right equipment, technique/know how and most importantly good paint, excellent results can be had from both rollers and brushes (and a combination of the 2).
Someone said about Rollys Royces having been painted by brush. In Europe (and starting to happen in the usa), due to the regulations in regards to spray painting, along with the associated costs of setting things up to abide by those regulations, many super yachts (big pricks like > 100ft) that are built there actually have the topsides of the hull (and possibly all exterior surfaces) topcoated via brush.......with a team of about 8 people.
PostPosted: Sun May 28, 2006 10:34 pm
and with por15 claiming you can still have outstanding results with brushes
i dont see why you couldnt do it.
