Clubman horn problem + Indicator glitch
https://www.ausmini.com/forums/viewtopic.php?f=2&t=19713
Author:  _666_ [ Tue May 30, 2006 10:43 pm ]
Post subject:  Clubman horn problem + Indicator glitch
anyone find that if theyre lights are on the horn doesnt work ?
and also i find my indicator are slow to react that they are on once selected...
Author:  willy [ Tue May 30, 2006 10:44 pm ]
Battery might be faaaaaarked...
Test the charge (off) and also charge running (and also at anything above idle)
Author:  _666_ [ Tue May 30, 2006 11:01 pm ]
nup it was ****ed but i replced it prolly no longer than a month ago....
Author:  willy [ Tue May 30, 2006 11:03 pm ]
Alternator charging?
Author:  _666_ [ Tue May 30, 2006 11:04 pm ]
the battery never seems to go flat... but the alternator light is always on...
Author:  Harley [ Tue May 30, 2006 11:09 pm ]
No biggie.....simply get one of those stickers:
"Horn broken, watch for finger"
:D
Author:  _666_ [ Tue May 30, 2006 11:09 pm ]
might i add the horn works perfectly when the light arnt on....
Author:  stuvz [ Tue May 30, 2006 11:55 pm ]
ok i have a clubman and whenever i would use my horn my radio would lose all power and all stations would detune, also when i come to a stop when my lights r on my radio turns off from lack of power. also yes, when stopped at traffic lights with my lights on my blinkers go slower. never had a problem starting it or anything and was a new battery.
i got my alternator fixed by an electrician friend, sumthin in it was all broken and stuff and it wasnt charging properly. and since then my horn works good and doesnt shut off anything... but still have the other problems but not AS bad, will get it fixed soon though cause i work nights and its a bit annoying and i want more speakers so they will take up more power.
haha thats my story, probably ur alternator not charging battery properly/fully, so u have enough power to do most normal things but added stuff is just too much 4 it. my horn is real quiet and lame and have had people laugh at it :oops: , so maybe dont use it at all and pretend u have no problem? :P
Author:  _666_ [ Wed May 31, 2006 12:05 am ]
hmm... k
ive had no probs with my radio...
just when i turn right or left.. it takes around 1-1?secs for the indicator to kick in .. its not instintanious.. the horns pretty simple to fix just dont use the lights.. lol my horn is kewl sounds good..
Author:  Mick [ Wed May 31, 2006 12:24 am ]
Sounds like you need to check the connections at the base of the steering column. The wires coming down from the indicator connect to the main loom a couple of inches past the end of the steering column shroud.
Also, take off the steering column shroud by undoing the screws and check the contacts at the base of the indicator stalk. Blowing/ brushing out the dust will do half the job, but some contact cleaner will finish it nicely. Before using this stuff though, check that it doesn't react with the plastic first.
Author:  jbeenz [ Wed May 31, 2006 6:17 am ]
also check ALL the earth connections, especially the strap from body - battery, and the big one in the engine bay. clean them up and you may notice a difference in all your electrical stuf.
Author:  feralsprint [ Wed May 31, 2006 9:34 am ]
means the alternator is not charging or if light is on but is dim the alternator is not charging at full rate :D
Jon
Author:  _666_ [ Wed May 31, 2006 2:24 pm ]
cheers for the help people...
