It is currently Fri Jul 18, 2025 1:42 pm
PostPosted: Wed Jun 14, 2006 12:03 am
has any one had this, i leave the keys in the ignition cawz the motor didnt start so i went to take a look under the bonnet and i went back inside the car to find that she wont let me back in and sure enough my doors wont stop locking them self, had to cut the hinge on the quater windows to get back in,
PostPosted: Wed Jun 14, 2006 9:27 am
hmmm never heard of it.
either slamming your door triggers the lock in your door
or your mini just doesnt like you :oops:
Inconspicuously Conspicuous
PostPosted: Wed Jun 14, 2006 9:41 am
Yes - I have heard of it - its a bad earth somewhere on the central locking circuit - you have to pull the door covers off and find it. Probably moisture and wear on a lead somewhere.
Presume you are talking about the Celica and not the mini.
PostPosted: Wed Jun 14, 2006 9:48 am
Maybe out of adjustment , will the door unlock with the key and open with the outside handle , or does the outside handle only just open the door even when you unlock it with the key ? The adjustment for the interior handle will affect the outside handle and if it's not right the doors can appear to lock themselves and be an extremely painful procedure . ANy clubman fans near you that can have a look at it ?
Or alternatively give the mini a good wash , polish and vacuum and some higher octane fuel , perhaps some new shiny bits as well ? We all know mini's are female and can get cranky if not treated right ......
PostPosted: Wed Jun 14, 2006 10:22 am
ausmini mod
ausmini mod
I wish I could lock my car :) but then again, I dont think I would want it to lock on its own.
Remove the door trim/skin/card and check whats happening. Its probably loose or not aligned properly.
Does it lock EVERY time you shut the door, or only when you slam it? Do both lock like this? (You dont have central locking installed do you?)
If it only locks when the keys are in it, and you get out to check something... then I agree with 68matic... it just doesnt like you :wink:
Peter.
PostPosted: Wed Jun 14, 2006 6:03 pm
na its the mini, worked it out the little piece of steel that wraps around the catch was just loose,
Users browsing this forum: Bing [Bot] and 93 guests
