It is currently Fri Jul 25, 2025 9:39 am
 Post subject: Bought me this....
PostPosted: Wed Jun 14, 2006 8:24 pm
This is even better the the other vizard book i bought, Modifying ur Mini. This has got soooo much information in it!!!
I was reading a section on twin 1 1/4 inlet manifolds and he goes into how poorly flowing a standard twin su manifold is. He also gives some tips on modifying the manifold to make it flow a little better, but........ Im thinking along the lines of an aftermarket twin 1 1/4in manifold. Does any 1 know of any decent manifolds around?
PostPosted: Wed Jun 14, 2006 9:36 pm
Came across this style, any 1 have any experence with this type?
http://www.minimania.com/InvDetail.cfm?Item=C-AEG488
PostPosted: Wed Jun 14, 2006 10:51 pm
I got a Maniflow inlet manifold out of UK last year.
Had it match ported to head-It's the best for twin SU's.
Not cheap. All-up $300.00.
PostPosted: Thu Jun 15, 2006 6:52 am
Have a look at www.calverst.co.uk for manifolds and filtration for su's. The Maniflow ones the same as LS1380 has are meant to be the best.
PostPosted: Thu Jun 15, 2006 6:56 am
If you are running twin 1-1/4s, even the old Lynx one is better than the stock Cooper/Cooper S one.
I don't think they are sold new any more but plenty S/H are still about.
It has a square balance pipe, and the radii inside are better.
PostPosted: Thu Jun 15, 2006 7:08 am
Was that to suit 1 1/2's or 1 1/4in S.U.'s???
PostPosted: Thu Jun 15, 2006 8:06 am
You only seem to be able to get the maniflow 1.25" manifold from www.calverst.co.uk . Everywhere else including Maniflow only list the 1.5"
PostPosted: Thu Jun 15, 2006 8:33 am
I'm using twin 1 3/4...
Sorry just read that article as well.Not listed for twin 11/4.
PostPosted: Thu Jun 15, 2006 8:59 am
Email Maniflow,
I got them to make me a twin 1.25" Manifold, it is bloody brilliant. Of course I had to get it chromed :wink: Just tell them what you want, didn't need to get mine port matched to the head, it was a perfect alignment! (12g940, ported and polished etc) Landed at my door it was around $260, then $50 for chrom plating in Aus.
They may only list the 1.5 or 1.75 twin manifold, but they do make them to your spec. Easy.
Got them to fix a bracket to the manifold for the throttle cable too. I can email you pics if you want.
Also, give Graham Russell a call, he told me he improved it by making the 'ports' longer.
PostPosted: Thu Jun 15, 2006 6:15 pm
SU Midel can do this style for $192.50
http://www.minispares.com/Product.aspx?pid=33131
PostPosted: Thu Jun 15, 2006 6:16 pm
That would be good if u could. [email protected]
PostPosted: Thu Jun 15, 2006 6:48 pm
i have one of these in spare (and some other HS2 parts, too)
but i think shipping would be to expensive
Rover 214 atm ....
PostPosted: Fri Jun 16, 2006 9:44 am
Pics sent! 8)
The alloy type you show are better than the factory manifold, but still a very poor cousin to the steel maniflow one!
matt
