22G1128
https://www.ausmini.com/forums/viewtopic.php?f=2&t=20220
Author:  sports850 [ Fri Jun 16, 2006 5:40 pm ]
Post subject:  22G1128
Just bought a job lot of rebuilt gearboxes , rebuilt motor and a ute load of new and rebuilt parts , the gearbox on the rebuilt 1100 is a 22G1128 and has hardie spicer joints . I'm a bit rusty on IDing remote change boxes but to my way of thinking it's a basic remote change 4 synchro box ? ALso has a temp sender (I think it is anyway) on the front of the gearbox housing .
Author:  TheMiniMan [ Fri Jun 16, 2006 5:44 pm ]
yeah, 4 speed syncro with "REVERSE LIGHT" switch --->(Not Temp sender)
could be a MK2 "S" box tho, check the leygear number???
Author:  sports850 [ Fri Jun 16, 2006 5:48 pm ]
Ahh OK , thank's Matt , I'll be stripping it down again before using it (I don't care if it's supposed to be rebuilt , I'm checking to be sure) and will check then , just seemed a bit odd for someone to have put hardy spicers on it but then again it's not difficult if you have them or the diff sitting about to use them .
I thought it was really odd to have a oil temp sender on the gearbox but couldn't think what else it could be , see what happens when you only play with rod change or 850 boxes :roll: :roll: :roll: .....
Author:  Mike_Byron [ Fri Jun 16, 2006 5:53 pm ]
Could also be an 1100s gearbox as well.
My wife's has that on her 1100s with original loom wires leading to it.
Author:  irossiter [ Fri Jun 16, 2006 6:57 pm ]
By what I've been told, that serial number simply means it is a 4 synchro box, not necessarily a Cooper S box. It is inside that counts. You will need to identify the gears.
Author:  drmini in aust [ Fri Jun 16, 2006 7:08 pm ]
If cluster gear is stamped 22G1040, it's a Mk2 S.
Having Hardy Spicer joints indicates it might be one, but the gears are the clincher.
:wink:
Author:  sports850 [ Fri Jun 16, 2006 9:41 pm ]
Ok , thank's guy's , I'll be sealing this motor up for a few months till I need it so will get back to you then about the numbers on the gears . I've got my fingers crossed though .
Author:  sports850 [ Tue May 01, 2007 7:22 pm ]
Stripped , checked and rebuilt the cheap motor with the unknown gearbox today , 20 though over 1100 never been started since the rebuild , std bearings , spotless crank .....
WOOHOO ....
The twins came with the motor , air cleaner I had sitting around and extractors are from my van .
Not sure but I remember someone saying factory cooper s cam's had two rings cast onto the blanks , anyone know if that's right or not ?
Author:  GT [ Tue May 01, 2007 7:46 pm ]
That part number rings a bell with me. GT maybe? Agreed on the "insode that counts" bit.
I believe you are right re: cam with rings on it.
Author:  drmini in aust [ Tue May 01, 2007 7:54 pm ]
GT box exactly same as Mk2 S box, with 22G1040 cluster gear in.
re the cam,
3/8 lobes with 2 rings (spider drive) is a Mini or Morris 1100 automatic.
3/8 lobes with 2 rings (pin drive) is 1100 Sprite Mk2.
1/2 lobes- Early S with 5/45-51/21 timing had no markings
1/2 lobes- Later S with 10/50-51/21 timing had 1 ring.
My source- Vizard, p262.
Author:  1310/71 [ Tue May 01, 2007 8:05 pm ]
And here's me thinking you just rattled them off your head - must be getting old eh Kev if you have to doublecheck your answers! :wink:
KB
Author:  gafmo [ Tue May 01, 2007 8:06 pm ]
No he's know the page number off the top of his head also :lol:
Author:  sports850 [ Tue May 01, 2007 9:14 pm ]
That would be it then , any ideas if it's slightly better than the equivalent 1100 mini cam or similar ?
I'm definitely liking this job lot of bits :D .
Author:  drmini in aust [ Tue May 01, 2007 9:32 pm ]
same timing and lift as an 1100 one. Suit RE13 regrind... :wink:
Author:  Lillee [ Tue May 01, 2007 11:18 pm ]
Nice find! i recently bought a 3 synchro remote and found a cooper laygear stamped on it and felt very happy indeed :wink:
