Stub Stacks
https://www.ausmini.com/forums/viewtopic.php?f=2&t=20225
Page 1 of 2
Author:  Hanra [ Fri Jun 16, 2006 6:44 pm ]
Post subject:  Stub Stacks
Any 1 know of any companys in OZ that sell stub stacks to suit 1 1/4in SU's????
Author:  drmini in aust [ Fri Jun 16, 2006 7:13 pm ]
http://www.uniflow.com.au
go to products,
auto sports & race.
:wink:
Author:  Hanra [ Fri Jun 16, 2006 8:41 pm ]
Ta Doc, but i was actually chasing the really short stub stacks, like vizard mentions in his book. It seems like just a low set stack which fits inside an aftermarket air filter. Im running Ramflo filters at the momment. I think he was using K&N ones.
This sort of style:
http://www.minimania.com/web/Item/SS50/InvDetail.cfm
Author:  drmini in aust [ Fri Jun 16, 2006 8:57 pm ]
people say those don't really work.
Try Keith Calvert's ones, available from his site-
http://www.gr8website2.com/calverst/shop.htm
Author:  Hanra [ Fri Jun 16, 2006 10:51 pm ]
According to Vizard they work, obviously not as well as a longer stack, but it takes away from that sharp edge that exists on the intake into the bore of the carb. He seems to have the flow stats to back his claims up!
That other type looks nice, good radii on the edges!!!
Author:  drmini in aust [ Fri Jun 16, 2006 10:56 pm ]
According to Keith Calver these K&N ones don't work, shape is wrong which is why he redesigned them.
I made some `Vizard elliptical design' shaped ones a while back for 40 and 45mm Dellortos and Webers but they won't fit an SU. Got no stocks of `em at the moment. :cry:
Author:  Hanra [ Fri Jun 16, 2006 11:00 pm ]
Yeah i think ill go for 1 of these 1s. They look really good.
Im going to modify my throttle shaft and butterfly as per vizard. Got 1 carb stripped this arv. Going to get one of these maniflow manifolds as well. Well hopefully they can knock 1 up to suit the 1 1/4in's?????
Author:  Mini68 [ Sat Jun 17, 2006 7:43 am ]
Calver stocks the maniflow manifold for the twin 1.25" carbs. Why don't you just get it from him along with the stub stacks? Save on postage that way.
Author:  Hanra [ Sat Jun 17, 2006 8:39 am ]
True deal! Ill have to sus it out some more. Thanks
Author:  Matt68 [ Mon Jun 19, 2006 10:13 am ]
Either way, make sure it has the right port size to suit the twin 1 1/4s. Mini spares flog off the same manifold for twin 1 1/4, twin 1 1/2, & Twin 1 3/4".
Maniflow will make one with 1.25" ports at the carb end, and ports that match the 12G940 inlets on the other end. As in the pics i sent you!
KC will probably have the right sort, but you will have to specify if you want a vac take off (brake booster or vac advance) & if you want a throttle cable bracket.
Best bet is to go with the twin 1.25" maniflow item, and the ultimate filtration kit from KC.
The ramflo elements filter really badly, even when oiled, so I'd bin them all together, and keep your motor healthier! The ITG element that goes with the KC kit is really good at filtering, with very high flow rates.
matt
Author:  Hanra [ Mon Jun 19, 2006 7:02 pm ]
That ITG element tho, is it resuable, wat happens if u need a replacement? Is it only sourced from the UK through KC???
Author:  drmini in aust [ Mon Jun 19, 2006 7:23 pm ]
matt
I agree the Ramflo filters are bad, but the UniFilter replacement foam pads are very good when oiled, and cheap too @ $8.90 each.
see http://www.uniflow.com.au/
scroll to sports and race.
p/no for the SU Ramflo ones is LNX300. :wink:
Author:  Matt68 [ Tue Jun 20, 2006 8:53 am ]
Um... Haven't looked into it yet. Supposed to be good for 100000 kms or something tho.
:wink:
Author:  Hanra [ Tue Jun 20, 2006 5:37 pm ]
Well im still awaiting to hear back from KC, i did recieve an email from him saying that he was busy and will reply to my email when he gets time......
Author:  Hanra [ Tue Jun 27, 2006 9:14 pm ]
Ended up getting a new inlet manifold, got one of the cast C-AEG 488's from Midel was $192 thought that seemed and ok price. Was gunna go maniflow but they are nil stock for like 6weeks, so is KC. So gotta fit the carby kits n get everything back together!!!
One quick q tho, i dont need a vac takeoff from the manifold. It has a large threaded hole in the balance pipe, where i assume a vac pipe would go. Other then just fitting a bolt into it, is there like a neat looking screw in style blanking cap available at all???? Maybe i should post a pic of wat i mean??
