Alternator problem
https://www.ausmini.com/forums/viewtopic.php?f=2&t=20241
Author:  The Toolman [ Sat Jun 17, 2006 1:09 pm ]
Post subject:  Alternator problem
I've just fitted a Bosch Alternator from a N13 Pulsar, and have it wired up as per instructions, but the problem is it doesn't seem to be charging. I wasn't able to get it tested from where I got it from, but it is under warranty
When I put the voltmeter across the B+ termianl with the wire disconnected from the solenoid, I only get a reading of .7V and goes up to 1.5 when I rev it,
Would a new regulator fix this?
Author:  9YaTaH [ Thu Jun 22, 2006 10:35 pm ]
Post subject:  undo some wires
Take off the wires where it feeds the loom....and see what the voltage reads then....you may have a short somewhere.
Double check the way you have wired it.
